Borgeson Power steering
Old Oct 25, 2020 | 01:08 AM
xMrFacex's Avatar
xMrFacex
Default Borgeson Power steering
I've pretty much buttoned everything up. I video taped turning the wheels so I could see if everything was going alright, but ya'll....... this ain't right....
https://youtu.be/uMSvFmOX_5o
How can I fix this?? :/
Old Oct 25, 2020 | 01:41 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Maybe it's just me. But your link doesn't seem to work.
Old Oct 25, 2020 | 03:05 AM
xMrFacex's Avatar
xMrFacex
You're not wrong, its rubbing against the control harm. Don't know why. The pitman arm is suppose to fit with the other components just fine.
Old Oct 25, 2020 | 04:33 AM
bfit's Avatar
bfit
The clamp on the adaptor looks wrong .
bfit
Old Oct 25, 2020 | 06:52 AM
bazza77's Avatar
bazza77
which pitman arm did you use ? looks tooooo long
Old Oct 25, 2020 | 06:54 AM
bazza77's Avatar
bazza77
copy and paste it into a new tab
Old Oct 25, 2020 | 07:03 AM
bazza77's Avatar
bazza77
double post
Old Oct 25, 2020 | 08:44 AM
Dazaa Rafae Aman's Avatar
Dazaa Rafae Aman
Could it be that you went from manual steering to borgeson and the pitman arm is for a non ps car?
Old Oct 25, 2020 | 09:12 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
That is not right, should not be happening. I seem to remember another thread here by someone having the same issue.
Your video:
Old Oct 25, 2020 | 09:04 PM
Petes73's Avatar
Petes73
On mine i had to reposition the clap so it didn’t interfere with the control arm.
Old Nov 15, 2020 | 04:29 AM
xMrFacex's Avatar
xMrFacex
Sorry for the late update, I've been doing a lot of other things lately. The unit is working without me making any changes. If you review the video, when the car is on, and it goes all the way to the right it pops into the correct possession off the control arm and was functioning correctly after that. When I filmed the test and saw it pop off the control arm I thought it was rubbing against it the whole time.
Petes73, as far as the position of the clamp, its as I said, I haven't made any changes to it, and it is not rubbing against anything, unless it matters that its turned the other way, idk, I just know its working.
Old Nov 15, 2020 | 12:41 PM
slofut's Avatar
slofut
I had a very similar issue. Finally gave borgeson a call and sent many pics, after several discussions they finally said they couldnt guarantee correct fit using aftermarket tie rod links ... Mine was close to the a arm flange, I relieved the flange a little with a grinder and all is well but I couldn't see another way. Had proper p/s pittman arm etc...
Love the Borgeson steering btw...
To Borgeson Power steering
