76 Transmission Mount/Bracket Alignment
Old Nov 10, 2020 | 07:32 AM
hgoodwiniii's Avatar
hgoodwiniii
Default 76 Transmission Mount/Bracket Alignment
Hi all, I'm trying to put my transmission bracket back on my 76. The holes are not aligning with the holes on the transmission mount. The mount, transmission and bracket are all original. Seems my transmission has shifted a bit (somehow) towards the driver side. Not sure why because the engine motor mounts or nothing else were removed at all. However, the main driveshaft, exhaust and crossmember were all removed and have been reinstalled. Anyone have any suggestions on how to shift it back to get the bracket holes to align with the mount holes? Thanks.
Old Nov 10, 2020 | 05:22 PM
carriljc's Avatar
carriljc
Post some pictures of what's going on under there so we can eyeball the situation.
Old Nov 10, 2020 | 06:32 PM
OldCarBum's Avatar
OldCarBum
How far is the misalignment?
Could be as simple as loosening the engine mounts and moving things around.
An old or warn engine mount could have pulled the trans over when you removed the trans mounting bolt from the crossmember.
Old Nov 11, 2020 | 12:54 AM
hgoodwiniii
Looks to be off about 1/2inch; I will post some pictures tomorrow. Thanks.
Old Nov 11, 2020 | 10:31 AM
gjohnson's Avatar
gjohnson
Loosen engine mounts and push the trans where it needs to be.
Old Nov 11, 2020 | 10:48 AM
OldCarBum's Avatar
OldCarBum
If they are the original engine mounts, now is the perfect time to replace them.
Old Nov 11, 2020 | 04:03 PM
interpon's Avatar
interpon
probably broke already// jack up engine and see..
https://www.corvetteforum.com/forums...ce-79-l82.html
Old Nov 18, 2020 | 08:06 PM
hgoodwiniii
Done! Thanks. I was able to pry the end of the transmission to the side just enough to get the bolt holes to align. Thanks.
To 76 Transmission Mount/Bracket Alignment
