C3 coilovers
Old Nov 15, 2020 | 02:35 AM
SoldmyWS64AC5's Avatar
SoldmyWS64AC5
Default C3 coilovers
Not sure if mods can move this?? Wrong forum and I'm unable to delete.
I purchased these from the forum, but now purchasing a car with ridetech setup already installed. This is for a small block. Low miles but was painted a really light gray and it flakes really bad. Little bit of surface rust on the rod ends.
FRONT
Splined sway bar
meyers tubular lowers
sdc uppers
Qa coilivers
Rear
Van steel rear coilover setup.. rear trailing arms offset for coilovers. I think one of the wheel studs is slight bent from shipping. 2750 shipped cont US. Shipping will probably 250.
Old Nov 15, 2020 | 06:36 AM
The Phantom's Avatar
The Phantom
FRONT
Splined sway bar
sdc uppers
Qa coilivers
Rear
What do you need out of the rear set up?
Dave
Old Nov 15, 2020 | 10:46 AM
SoldmyWS64AC5
Sending you a PM!
To C3 coilovers
