temperature sensor
Old Nov 15, 2020 | 06:37 PM
JesterJim's Avatar
JesterJim
Cruising
Default temperature sensor
I believe the temperature sensor in my engine is bad. The gauge hardly moves after the engine is started and runs up to temp. I have tested the gauge and it does work per the trouble shooting guide. My question is that when I went to replace it I noticed that the new one has about a 3/4" across the threads and the one in the drivers side of the engine between spark plug 1 & 3 is about 1/2". The parts house ordered a different one and it has the same size threads. What am I missing?
1978 C3, 350 engine, 4 speed - this is not the original engine and I know nothing about the engine other than it is a Gen 1 chevy 350.
Thank you in advance!
Old Nov 15, 2020 | 06:46 PM
MelWff's Avatar
MelWff
The engine temperature gauge sensor is on the drivers side head.
Are you sure you dont have a thermostat stuck open?
Have you rented a IR gun to confirm reading?
Old Nov 15, 2020 | 06:47 PM
Petes73's Avatar
Petes73
The newer heads used a smaller temp sender.
Old Nov 15, 2020 | 06:50 PM
JesterJim's Avatar
JesterJim
Cruising
That would make more sense, but then how do I order the proper one?
Old Nov 15, 2020 | 06:55 PM
JesterJim's Avatar
JesterJim
Cruising
Yes, the sensor I am working on is on the drivers side.
Not sure if the thermostat is stuck or not. I am not having issues with it over heating, I just want the gauge to work.
No, I haven't rented an IR Gun. Didn't know that is possible and will in the future.
Old Nov 15, 2020 | 07:02 PM
ignatz's Avatar
ignatz
This "sender" is about the simplest device you could imagine, just a temperature sensitive resistor. Have you tried removing it, tested that its resistance does indeed change with heat. Cleaning the threads to get a clean electrical contact and reinstalling it might be all it needs. My experience with the newer "senders" is that they are calibrated differently and as I remember don't fit all that well even after you finesse the difference in diameter.
As far as renting an IR detector, these are really cheap. Handy in the kitchen as well, you should have one in your toolkit as well as a multimeter to measure electrical stuff.
Old Nov 16, 2020 | 09:50 AM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
If you have the original temp gauge in the dash there is no sender available that will work correctly with the gauge. Ask me how I know.
Old Nov 16, 2020 | 10:26 AM
HeadsU.P.'s Avatar
HeadsU.P.
The average Joe will install a new temp sensor with a gob of thread sealant. This action keeps the unit from grounding itself to the head. Or in laymans terms, denies a complete circuit.
Two options when installing. Only use sealant on the bottom few threads. Or use sealant tape. The threads will cut the tape for good contact, yet seal-in coolant.
If your name is not Joe, you don't have to worry about it.
Old Nov 16, 2020 | 10:39 AM
JesterJim's Avatar
JesterJim
Cruising
Good news, I'm Jim and not Joe! I understand what you are talking about as far as the thread tape. In my line of business, less is better and none is preferred. If this leaks around the treads, I have bigger issues. Thanks
Old Nov 16, 2020 | 10:40 AM
carriljc's Avatar
carriljc
Go to the Willcox website and order the temperature adjusting resistor.
Don't struggle with other solutions.
Order the adjustable resistor and in dial your gauge in with your present sender.
https://willcoxcorvette.com/corvette...resistor-77-82
I *think* your original post states that the sender you have installed at the present time is 1/2"? If so, then you can just order that from Willcox also...... but your local parts store should have one..... not rare.
Old Nov 16, 2020 | 10:41 AM
JesterJim's Avatar
JesterJim
Cruising
I was given some advice to use the same one that goes into an '82. They have the smaller hole that I need and it's the same gauge. I'm going to try it and if it doesn't work I'm only out $30
Old Nov 16, 2020 | 10:44 AM
JesterJim's Avatar
JesterJim
Cruising
The problem is that this is not the original engine and these heads are aluminum and the hole for the sensor is smaller. I have already decided that once I get a sensor that fits I will install the adjustable resistor. Thanks
Old Nov 16, 2020 | 10:52 AM
BKarol's Avatar
BKarol
Contact Willcox and inquire if this will work. :https://willcoxcorvette.com/corvette...79-3-8-npt-new
Old Nov 16, 2020 | 10:54 AM
JesterJim's Avatar
JesterJim
Cruising
Thank you! This is a great option.
Old Nov 16, 2020 | 01:05 PM
HeadsU.P.'s Avatar
HeadsU.P.
Yes, that was a shock that my new aluminum heads would not adapt to the stock sender. Luckily, I caught that before installing the heads. A quick trip to the machine shop, drilled and tapped ($30) for the old sender.
Old Nov 16, 2020 | 05:07 PM
Capt. Shark
As I understand it, though, you must remove the center gauge panel to get to the back of the circuit board. Is this correct? On a 40 year old car wonder what all you would inadvertently destroy just to get a correct reading gauge?
Old Nov 16, 2020 | 06:41 PM
carriljc's Avatar
carriljc
I understand. I couldn't decipher your original comment about 3/4" and 1/2". I see now that you have a 3/8" hole.
Nevertheless, call Willcox and they'll set you up with what you need.
PS- I actually have a 3/8" sensor installed so I can see if I can dial it in to work with my 68 gauge---- I just haven't done anything since I was able to dial in my 1/2" sensor that is now installed on the intake manifold next to the thermostat housing. Works like a dream.
To temperature sensor
Old Nov 16, 2020 | 10:44 PM
theandies's Avatar
theandies
When I installed my ZZ4 the head location on it was the small diameter hole. I bought a sender to fit there but the calibration resistance was different. I put my original on the intake right next to the thermostat housing the used my IR temp gun to see the difference in temp at the head location vs. the intake location. Of course the intake was 10 to 15 degree cooler so I just keep that in mind when looking at my water temp. I would get one of Willcox's adjustable temp resistor (or make my own) but I don't feel like ripping the dash apart.......again!!!!
Old Nov 17, 2020 | 12:24 AM
carriljc's Avatar
carriljc
Yah... I lived with my inaccurate gauge for decades. I don't even mind tearing it apart any more.... I recommend doing the adjustable resistor.... I did mine like 3 years ago and I'm still happy when I drive it and the gauge reads appropriately.
Old Nov 17, 2020 | 07:08 AM
stingr69's Avatar
stingr69
The specific bore required for the larger pipe thread tap is actually very close in diameter to the existing tapped hole minus the threads. If you just grind the existing threads out, you are ready to retap the new hole for the larger size pipe thread. Saves a trip to the machine shop.
