81 lock up trans?
Old Nov 16, 2020 | 03:47 PM
eddp's Avatar
eddp
Default 81 lock up trans?
This has probably been beaten to death, but it came up on another blog.
What, if anything really happens if you delete the ecm and don't add a manual converter lock up switch? I've talked to several trans shops and they basiclly say it's no big deal. Won't damage anything and won't really affect performance much.
Comments????
Old Nov 16, 2020 | 05:14 PM
Eric P's Avatar
Eric P
It won't hurt anything on a Turbo 350C but you do lose a few MPG and 200 to 400 rpm on the highway ..
Old Nov 16, 2020 | 08:10 PM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
I've driven mine about 3K miles without any lockup. In our case '81 autos come with 2.87 gears, so some slippage is welcomed.
Old Nov 18, 2020 | 12:16 AM
7T1vette's Avatar
7T1vette
With that vintage of THM-350 there will be no problem if you don't employ the lockup function. But that is NOT the case with more modern autos. When using lockup, less heat is generated inside the trans. Modern cars are made with the assumption that the L/U system will be activated on a regular basis, minimizing the chance for overheating. If you turn the L/U system 'off' on modern vehicles, overheating could take place.
This design concept was initiated in the 1980's. Also at that time, the design of the lockup clutch components was sinnied down to minimize weight, so they weren't as strong as the earliest lockup hardware. There are a lot of concerns regarding proper use and engagement of L/U clutch systems, so do your research and think about any alterations you may wish to do with a lockup type transmission.
To 81 lock up trans?
