Max pump gas compression
Old Nov 20, 2020 | 03:56 PM
platinummaker's Avatar
platinummaker
Default Max pump gas compression
I know we have some savvy engine builders on the forum and I am requesting your opinion on max static compression for a 91 octane, (California),pump gas, aluminum head, carbureted, small block Chevy. Cam will be very mild with 218/220 duration, 495/512 lift and 112 lobe separation. Don’t want to get too greedy and have to use octane boosters or mix in race gas, or retard timing to reduce/eliminate pinging, but at the same time don’t want to leave some usable compression on the table
Opinions please. Thanks much
Old Nov 20, 2020 | 04:38 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Plug your engine numbers into a DCR calculator. If its below 8,5, you MAY be ok. My DCR is about 8.3 with a 10.7 cr and it runs on 91 octane up here in Canada
Old Nov 21, 2020 | 11:15 AM
C3TPI's Avatar
C3TPI
Yes, it all depends on your dynamic compression ratio not static, and that is controlled by your cam timing events.
Old Nov 21, 2020 | 11:49 AM
joystick's Avatar
joystick
Also depends on comustion chambers design. If you have fast burn chambers you’ll most likely run less ignition advance at WOT and thereby less prone to knock. But as said above, DCR determines a lot.
Old Nov 21, 2020 | 12:11 PM
cv67's Avatar
cv67
St. Jude Donor '05
w/joystick...Get an AFR 180 head or 190 vortec....those combustion chambers are awesome for detonation resistance. You can run a lil more compression and timing for sure. It does help...imo more than the "only adds xx %
OP if you like I can pm you the nuber of a member who is an afr dealer, get it cheaper than Summit
AFR is having a price increase Jan 1 think its 50+ perset.
Old Nov 21, 2020 | 01:25 PM
REELAV8R's Avatar
REELAV8R
https://www.jeepstrokers.com/forum/calculator/
use this calculator to computer you DCR with that cam.
keep it under 9.5 : 1 for aluminum
under 9.0:1 for cast iron.
I currently run up to 9.2:1 DCR with 91 and no issues.
Edit: Sorry fat fingered those. 8.5 aluminum and 8.0 cast iron and I run up to 8.2.
I am running aluminum heads. AFR's
Old Nov 21, 2020 | 03:24 PM
HeadsU.P.'s Avatar
HeadsU.P.
Everything I read on Dynamic Compression Ratio states that ideal DCR is between 8.1 - 8.5.
Lower than that is loss of power. Higher than that is loss of everything. (grenade)
Old Nov 21, 2020 | 03:35 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
With a fast burn chamber you could get away with 10.0 to 1.
Jebby
Old Nov 21, 2020 | 05:41 PM
7T1vette's Avatar
7T1vette
9.5 to 10.0 should be achievable with aluminum heads.
I have 10.5:1 Pontiac engine with iron heads and it runs fine of 93 Octane. It likely would ping with 91 octane fuel.
Some gyppo fuel stop sold me Premium fuel for my Pontiac...ONCE...and it ran like total crap. They were putting 'regular' in every tank and just charging folks the premium price, figuring that the modern electronic controls would still make the engine run OK. Didn't work on my Pontiac.
Naturally, I went back to have a "talk" with the owner.....
Old Nov 22, 2020 | 12:48 AM
joystick's Avatar
joystick
There is a little bit of apples and oranges in this thread now.
I would say, do NOT go above 8.5:1 DCR, whatever that will be SCR all depends on the cams IVC.
As mentioned above, run a DCR calculator.
Old Nov 22, 2020 | 09:25 AM
jb78L-82's Avatar
jb78L-82
I have AFR 180's with Howards Roller Cam (Duration 219/225, Lift .525/.525, duration 110) with 1 7/8 inch headers with straight through C4 Borlas Type S muffles with 34 total timing, Aluminum L-82 intake and holley 4175 Vaccum secondary 650 CFM Qjet spreadbore type carb (lots of details here). Total static compression is 10.2:1. Engine runs perfect with Zero detonation with 89 octane......
Old Nov 22, 2020 | 10:09 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
The SCR is independent of the ivc point but its the DCR that is calculated using the ivc point. For higher scr's, longer duration cams are needed to bleed off cylinder pressure and reducing the risk of detonation. As mentioned, a DCR for aluminium heads on pump gas is 8,5 max and 8.0 for iron heads.
Old Nov 22, 2020 | 10:14 AM
REELAV8R's Avatar
REELAV8R
Another thing that is just as important is the quench distance. Keep that between .035" to .040" and you'll reduce the possibility of detonation a lot.
So if the block is still stock height then the pistons will reside .025" in the hole with stock compression height pistons. Use the felpro .015" shim head gasket and you'll get .040" of quench. Too big of a quench and you'll not get the advantage of a good tight quench increasing the likelyhood of detonation.
I run .038" of quench 10.6 CR with, like I said, a max of 8.2 DCR and I can still run 87 octane with no detonation. That being said the cooling system needs to be well sorted as well, and the timing and the jetting and I have a true cold air intake to keep the fresh intake charge temps down. So it all matters in the end, but having the CR, DCR and the quench right is the place to start.
Old Nov 22, 2020 | 10:32 AM
REELAV8R's Avatar
REELAV8R
If I assume that the advertised duration of your cam is 272* intake and a 4.0" bore with a .040" quench (.025 in the hole and .015 gasket) and a 7 cc flat top piston, 64cc heads, 4* advance on the cam (standard) then I get 8.06 DCR and 10.03 CR for your cam at sea level.
Bringing the bore up to 4.030" gives 8.16 DCR and 10.15 CR
So 10.0:1 CR will put you in the safe zone with good power.
Old Nov 22, 2020 | 10:34 AM
augiedoggy's Avatar
augiedoggy
I have a similar setup that you actually advised me on building 6 years ago... after digging up the exact measurements, I have a .037 quench 10.3:1 static and 7.6:1 dcr with the voodoo 262 cam im running which bleeds off pressure and allows me to run any pump gas. Although I run 89 or higher to be on the safe side and also because I use the non ethonal gas whenever possible...
Actually I had a related question which this thread has helped answer here since I have been considering swapping out the crank with a scat 383 crank which should raise my static to 11:1 and my dcr to 8.2:1 sounds like I would still be ok even with my iron eagle heads.
Old Nov 22, 2020 | 10:59 AM
REELAV8R's Avatar
REELAV8R
If I was to go to a 383 with 11:1 CR, I would want a cam with more duration or narrower LSA (both likely) to take advantage or the rev potential. With the 262 cam on a 112 your gonna limit the power due to low RPM potential.
With your current set up I ran a few numbers to get a 10.3 CR and I come up with about 8.6:1 DCR with the 262 cam at sea level. Is your DCR drop due to running at about 5000 feet?
Old Nov 22, 2020 | 11:56 AM
augiedoggy's Avatar
augiedoggy
Not sure I simply changed the stroke in the calculator and likely did something wrong. I have the 4 relief- 6.9cc flat tops and a .015 steel head gasket with 64cc heads that sit .022 down at tdc. I had a hard time finding the ivc to use but did find Harold UD posted it was either 37.5 or 34.5.. I have it documented at home and I am at my hunting camp at the moment. I have 3.08 gears and am mainly looking for as much torque and power as I can get below 5krpm.
Oh yeah.. 4.030 bore
To Max pump gas compression
Old Nov 22, 2020 | 12:11 PM
jb78L-82's Avatar
jb78L-82
I think I know what you were trying to say about the 383 power potential but a 383 with a longer stroke than a 350/355 makes more power at the same rpms as the smaller displacement 350/355 at that same rpm. The 355 actually will rev more easily than a longer stroke 383 to make similar TQ at a higher rpm. Any shorter stroke engine will rev much easier to high rpm than the longer stroke motor of the same design and cylinders.....
Old Nov 22, 2020 | 02:05 PM
HeadsU.P.'s Avatar
HeadsU.P.
Thanks Joystick. You noticed that too. Not everybody was on the same page.
I was referring to Dynamic 8.1 - 8.5 With the max being 8.5 for safe operations.
Static, on the average is two points higher.
Old Nov 22, 2020 | 02:29 PM
platinummaker
Thanks to all for the great feedback. I ran the numbers through a DCR calculator and came up with 8.6. I am running some really nice AFR aluminum heads so I am assuming I should be good. Thanks again
