Torque setting Flywheel
Old Nov 21, 2020 | 10:03 AM
Rob Via's Avatar
Rob Via
Default Torque setting Flywheel
What should I torque the 3 bolts that connect the flywheel to the torque converter? 383 motor and th350 trans. around 450HP.
Old Nov 21, 2020 | 10:45 AM
lars's Avatar
lars
35 ft/lbs. But more importantly, make sure you put a drop of LocTite on the bolt threads. Those bolts have an odd tendency of wanting to back out, and when they back out far enough, the bolt heads will hit the tranny case during engine operation, and they will break the case...
Lars
