Next step
Old Nov 28, 2020 | 07:33 AM
Steve Kistler's Avatar
Steve Kistler
Reset the timing to 14* and total @ 41* I changed accel pump rod to bottom hole and reset a/f mix and it runs like I had expected hoped from the start. Now after my fill up I will see if my mileage improves. I wish I had all the money I pissed away because of the Mantra of the day. I am sure I am not alone lol
Old Nov 29, 2020 | 12:34 AM
7T1vette's Avatar
7T1vette
If that 14* at idle and 41* max are with the vacuum advance still connected, you still have more 'left in the tank'. 34* max without the vacuum advance would be ideal (for most Chevy street engines).
And, if by chance, the 41* is without the vacuum advance (can't imagine it, actually), you need to back the timing down.
Old Nov 29, 2020 | 02:05 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
basically, recurve your distributor to get 16 - 18 degrees at idle. 35 - 36 all up with vacuum unhooked. and all in around 3 thousand. then check your vacuum advance can to see if it matches up to your vacuum. replace nessesary.
Old Nov 29, 2020 | 10:53 AM
Steve Kistler
With vac adv. disconnected I hit the numbers of 16* at idle /700rpm and 34* @3k rpm. I finally think I can outrun my Escape...lol thanks for all the help
