Chasing a rumbling vibration down
FedEx delivered this morning the new low-profile, polyurethane transmission mount.
Before noon it was in the car and I was out for a test drive.
My test drive was short because of rain. Aaand - it seems, seems... that fixed the problem. The car is much more comfortable to drive. No rumbling vibration in the transmission tunnel or footwell.
I need to tweak the exhaust pipe a bit; it’s slightly banging against the seat bolt... but other than that, I think the problem is solved.
More testing to follow
I now think there might be a small balance problem or the exhaust just drones in an annoying way.
Tomorrow I’ll run it parked at at 3000 rpm with a hand on the valve cover.
i would also doublecheck engine mounts..they are tricky to see until you jack up oneside of enginethen other..the rubber seperates..
(Note: trans mount bracket is tight and the tranny lowered away from the body.)
I no longer think it’s the balance of the engine.
I did the glass of water test and... it passed. In fact it passed with high marks.
At idle the water in the glass was clearly disturbed. As I brought it up in rpm, the water went completely flat. And I mean flat.
The only thing I can think of now is exhaust resonance. In order to fit the T5 I removed the center exhaust hangers located at the transmission mount.
The exhaust pipes are hanging only from the headers and the mufflers. Nothing is supporting them in the middle. I’m thinking under load that must be resonating. It’s not touching the holes in the trans cross member.
I do emphasize that the it always seemed to me that the vibration was in synch with the exhaust popping. Sort of a rumble.
I got it from here.
https://conversioncrossmembers.com/p...on-mount-02-b/
Hmm. I think the price went up $10 since a few weeks ago
It seems that the vibration/rumble comes and goes between 2500 and 3200. Above 3200 it seems to be gone.
At idle the exhaust tips seem to shake a lot - so tells me a sneaker sole resting on it. They don’t seem to be firmly located.
I popped under the car and checked the hangers.
The look pretty flimsy to me. Maybe it worked for a very mild 350.... but not so much for a high performance V8 ?
I will need to measure the exhaust pipes again but to me they look closer to 2 than 2.5 inches.
Muffs are some kinda Flowmasters.
https://youtu.be/doHn89m_27M
https://www.corvettecentral.com/68-7...ounting-323289
You will note that the LOWER end of the bracket bolts onto the stock mufflers, and you can see that in this image:
https://www.corvettecentral.com/c3-6...2f%3fcount%3d9
Anyway, I have a 2.5" system from the front to the back and it doesn't rattle nor rumble. I went to essentially a stock parts 2.5" system with stock mufflers a couple of years ago after having headers and fabricated exhaust for 30+ years.
I added the pictures from the corvette central webpage in case the links change in the future. I rotated the support brackets so it's easier to visualize how they bolt onto the frame. I was surprised/happy how well it all fit to my car after 30+ years of a fabricated exhaust.
I really wish I had a stock exhaust set up
Been doing a lot of reading about C3 corvettes, glass bodies and, Flowmaster 40 muffs... and I think I’m experiencing droning.
Droning apparently is a resonance that is felt in the cabin, not just heard. From what I read, I t’s not uncommon in C3 corvettes with loud muffs and usually happens at a set RPM band.
Changing mufflers is one solution. Car Chemistry inserts is another. Finally a cross pipe can also help.
New mufflers and or exhaust pipes can get pricey quick, especially shipping the whole kit and kaboodle over here, Belgium.
Inserts behind the collectors, I think are the easiest and cheapest solution... but there will be a price to pay in power for the muscular 400 SBC.
Finally a crossover might help - splitting and diminishing the pulses. It’s not too expensive... excluding labor, which may be hard to find here. And it may make dropping the exhaust a pain later on.
I think the best idea is to start with the inserts and see if that makes a difference.
You can place the cross-over at the rear -- like underneath the spring area. That's where mine was before I changed to stock exhaust..and that's where I plan to cut and weld one in again. Should be easy there.
