Crack intake update
Old Dec 16, 2020 | 11:55 AM
4speed69's Avatar
4speed69
Default Crack intake update
Triangle Filed it, acetone and then JB weld. Finally sanded. We will see if it holds
Old Dec 16, 2020 | 12:36 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Use an ARP bolt kit.....put some moly between the washer and the bolt shoulder....this will keep the washer from trying to spin when you tighten which will try to spread it open. Tighten just snug....do all the others in a pattern and tighten that one last....2-3 steps.
Jebby
Old Dec 16, 2020 | 12:51 PM
4speed69's Avatar
4speed69
Jebby
That sounds like excellent plan. Thanks
Old Dec 16, 2020 | 01:05 PM
Greg's Avatar
Greg
Just another Corvette guy
Nice looking repair.
Old Dec 19, 2020 | 04:51 AM
7T1vette's Avatar
7T1vette
Not that good looking for a bare aluminum intake, IMO. Less that $20 would have netted a simple heli-arc weld job so that the repair could not be seen.
Old Dec 19, 2020 | 07:26 AM
4speed69's Avatar
4speed69
It was still wet, i will try and take another picture. You can't see the repair. 20 dollars seems awful cheap to have anything done, unless you know the person or they are desperate.
Old Dec 19, 2020 | 08:21 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Post up your work my friend. Lets see your professional work
Old Dec 19, 2020 | 04:15 PM
7T1vette's Avatar
7T1vette
What the he!! is that supposed to mean? I would do the same thing I recommended to the OP....have the part heli-arc welded to make it RIGHT.
Are you an "agitator", "instigator" or just a "meddler"? I'm sure the OP can respond without your "assistance".....
The OP prepped the part extremely well: nicely grooved and clean....ready to weld. The JB Weld epoxy will make a "functional" repair and probably last quite a while. But the repair would be hard to miss when looking at the engine, and with that valuable/desirable intake, a proper fix would have been best, IMO.
Old Dec 19, 2020 | 04:51 PM
ramair_bryan's Avatar
ramair_bryan
Relax
Old Dec 19, 2020 | 05:13 PM
Rescue Rogers
Guess you should have started your comment with a complement like that "The OP prepped the part extremely well: nicely grooved and clean....ready to weld. The JB Weld epoxy will make a "functional" repair and probably last quite a while. But the repair would be hard to miss when looking at the engine," Then added the part about it being able to be seen.. It may or may not depending on how the valve cover hides it..Merry Christmas
Old Dec 19, 2020 | 05:19 PM
cv67's Avatar
cv67
St. Jude Donor '05
Sure welding is better but hes got nothing to loose really. Not like his car is going to lose value, my god people.
Its 50 yrs old who cares
Old Dec 20, 2020 | 09:33 AM
7T1vette's Avatar
7T1vette
Most of us on this Forum CARE about our cars and try to help other folks who CARE about theirs.
Why are you here?
Old Dec 20, 2020 | 12:32 PM
Rescue Rogers
Why are you here?
Okay lets compare numbers on what I am doing here
Ive been here since Oct 2015...just over 5 years..I only have 8721 posts. You have 34,196 posts in just shy of 15 years... almost 6 times as many but our likes are the same....Seems to me that if you were being so helpful and courteous to folks you would be helping with vacuum leaks, electrical problems, posting "how to's" on different things you have fixed or changed in your car, you would have 6 times as many likes as me. You want to go through threads we both started and see who is trying to help out friends here?. Do you want to go through posts and see who actually tries to engage people and add something constructive and see who reads the previous posts then reposts the same info as their own? Do you want to go through our posts an see how many of them are negative towards the threaad starter.... Im willing.
How about you calm down. Stop calling out the guys that try to help out the new guys and you just sit there and think positive thoughts and stop belittling guys that ask a simple question. If you go back to the beginnning of the thread I said the same thing you did about welding the intake and getting it remachined. I just want an ******* about it. If you dont like the JB weld keep it to yourself
Old Dec 20, 2020 | 12:36 PM
Rescue Rogers
Sorry 4speed69 about causing a stir in your thread.
Old Dec 20, 2020 | 03:04 PM
7T1vette's Avatar
7T1vette
RR...
Save your 'pontification' for someone who requires it. You are just another self-righteous, egocentric jerk. But, that's only my opinion.
Old Dec 20, 2020 | 03:10 PM
Rescue Rogers
HAHAHAA! Thanks, I like it when Im called names with multiple syllables
Old Dec 22, 2020 | 08:32 AM
4speed69's Avatar
4speed69
I did do alot of reading on this fix. I guess I will see what happens. I was really proud of the way it turned out and wanted to share with the picture. I will always keeps a eye on it and if if needs repaired again anytime soon, I will weld it. I understand the repair should last many years. Thanks for the input and Merry Christmas.
To Crack intake update
