I'm starting to look for a BBC to toss into my SBC 79. This is going to be a temporary engine (just something to get the vehicle running) while I keep working on other parts of the vehicle. If I try to "build" the BBC I'd like, I'd be several years getting anything done. So this is a stop gap to keep moving in the right direction.
I'm running a Holley Sniper Stealth fuel injection and in-tank fuel pump, so I don't need the mechanical fuel pump boss on the block.
A number of the local wrecking yards have both Mk4 and Gen 6 BBCs available, so I need to figure out what I go with. I'm inclined towards the Gen 6 because:
it's a roller lifter block
9:1 CR
1 piece rear main seal
Is there a reason I should go with the Mk4 engine? I have to buy a new flywheel (since my car was an automatic and I'm swapping in a T56), so this is entirely blank slate.
9:1 CR
the biggest concern would be lack of a fuel pump boss on the gen 6 blocks. If you
plan on using an electric pump that is no issue.
as for the roller cam, mark 4 blocks are easy to add it. The screws are in the block for a stepped nose cam. You just need link bar lifters.
Gen 6 is also priority main oiling and every one has 4-bolt mains. Easy cam retention and OEM lifters to about .625" or so lift. To me, it's a no-brainer. I only have a half dozen or so stacked in the corner and I grab every one that comes up at a reasonable price. Oh, and if you fall in love with a 1-piece RMS crankshaft, a $100 adapter lets you use it in a Gen 6 block. Can't go the other way.
Gen 6 all day. This coming from a guy who has a 496 based on a MkIV block. The fuel pump and clutch stud drove my thinking but now I am running EFI and could easily swap to a hydraulic T/O bearing. I have been living with a small but annoying rear main seal leak for about 5 years now. Would love to have the one-piece RMS.
If starting from scratch the Gen6 is the better choice because of the main seal......but remember these blocks when running ANY aftermarket head will require the right head gasket: https://sdparts.com/i-21078748-victo...mk4-heads.html
The Victor Reinz gasket is excellent......as is the Fel Pro which I believe is part # 1047
Jebby
Are either of those a multi-layer metal gasket? Coming from LSx builds, I'm partial to the multi-layer metal gaskets as that's what I'm used to.
Nope....call Cometic.
Unless you are using over 400 shot of nitrous....or 12-13 psi boost....MLS gaskets are unnecessary. At $100 a side.....it is something to consider.
