I'm shopping for a new clutch to use when I reassemble my '71 coupe. The original 350/270 engine has been rebuilt with a mildly upgraded intake and roller cam & rockers, but I stayed with the original 487 heads. Tranny is the original M20 4-speed. Car will be a weekend joy rider, not a racer. After reading the thread about clutch disengagement clearance distances, I'm interested in using McLeod clutches. But first I want to to get some input from the forum on the difference between the 11" Street Level ones and the Street Pro ones. I know the SLs are good for up to 300HP/300TQ and my engine might be getting close to that, especially if I upgrade the exhaust for better flow. That then moves me towards the SPs which can handle 400HP/400TQ.
Both are single organic discs, so what allows the SP to handle more power?
Is it simply a difference in the pressure plate clamping force or something in the disc springs or disc composition itself?
Will the SP require more pedal force to disengage the clutch? [just in case my wife "steals" (borrows without my knowledge) the car for a joy ride ]
The Street level has a fiber friction plate on both sides......the Street Pro has ceramic on one side (I believe the flywheel side).
I have the Street Pro and it is as good as it gets for pedal and grab......not heavy at all.
I had both the McLeod 75121 Street Pro and it was fine, I upgraded my motor to a 383 stroker and got the 75221 Super street pro and it's great. 75121 is rated for 400 HP, and the 75221 is rated for 500 HP. The 75221 is not a heavy clutch and has worked perfectly for me.
Jebby
just trying to help out one of the best guys on the forum...
the “super” street pro is the model with a ceramic side that faces the flywheel.
the street pro is organic on both sides.
I’ve had both of these clutches and both perform well. My experience after going to replace the super street was that the ceramic side chewed into my flywheel pretty good. In my opinion the ram power grip is a better set up with the ceramic facing the pressure plate.
anyway that’s a bit off topic. I don’t know what makes the power threshold lower on the street level vs the street pro, but I’d put the street pro behind most non-crazy motors without a worry. It’s a perfect upgrade for stock replacement, and a bit further up the food chain too.
2016 C3 of Year Finalist
I talked with McLeod looking for part numbers from the pressure plates....they are all the same, all the torque and Hp differences are in the discs materials themselves. I smoke a street level clutch before. The super street pro is very nice.
McLeod has a break in period with their clutches as well which makes a difference on their life and quality of drive
The McLeod Street Pro 75121 has a 26 spline disc. I think your Muncie has a 10 spline main shaft. Not compatible unless they are swapping the disc for you.
Summit and McLeod both said the 75121 was correct for my year Corvette. You got me worried that my memory of many more than 10 splines was screwed up, so I just had to double check...
Much to my relief, I quit counting after 16 splines so I believe I'm good to go!!
Paul
Ok.Cool. The M20 in my 65 was a 10 spline. I guess in later years they changed to 26.
Sorry if I confused things.
Tom
