The roller tips will give you less friction and you'll gain a small amount of additional lift. But I wouldnt expect a seat of the pants noticable improvement like you would feel with headers or new heads.
The 1.6 rockers will give you more lift and may give you a little more power. And it may even be worthwhile.
I don't see it being enough of a change to throw your system out of whack.
But Ive never been a fan of the cross fire system.
I did this on an 84 Mastercraft ski boat I restored about five years ago.
I noticed it smoothed out and raised the idle rpm a little.
The only improvement I noticed was a very little quicker throttle response, but no overall performance gains.
It was worth doing.
One thing no one has mentioned is pushrod to cylinder head clearance where pushrod goes through the heads. Many OEM sbc will rub here and hole must be elongated. Check carefully.
One of the biggest advantages, besides more flow under the curve, is reduced side load of the valve stem to guide reducing wear. Neither which OEM mfg care about as long as it makes it off warranty.
If roller tip rockers are so great, how come the 436hp LS3 engines don't use them?
What will you gain by using them?
The roller tip rockers for generation 1 small blocks are a true 1.52 or 1.6 rocker, the factory rockers for generation 1 small blocks turn out to vary a great deal and are generally 1.37 not 1.5.
Read this paper for more details on the 1.37 ratio. Solid Lifter Cam Valve Adjustment
The roller tipped rockers are superior to the OEM rockers and there are a multitude of reasons why GM did not and does not use them on every OEM motor today, none of which is to the buyer's benefit, most of the time.
I have a set of comp cams roller tipped 1.52 rockers on my L-82 355 which I put on the OEM L-82 motor with the OEM 882 heads in the early 2000's and then reused on the upgraded/rebuilt L-82 355 in 2014 with the fabulous AFR aluminum heads.
The quality of the comp cams roller tipped rockers is FAR superior to the OEM rockers which as pointed out are a stamped steel piece with a ratio of something less than 1.5!
I have thought about using the comp cams 1.6 ratio rockers on my L-82 355 since switching from the 1.52 rockers to 1.6 roller tipped rockers would give me approximately 5% more ratio from the .525 lift roller cam to .550 which would be ideal with my current roller cam specs and the AFR's for max power.....
Watch out using cheap roller rockers off Ebay. They will 'eat' the ends off your push rods and you will end up with an engine full of metal bits. You have to use a hardened push rod with these rockers and the stock ones will not cut it. I had to tear one engine down because of this problem. The 'shortened' push rod damaged a lifter and the snap ring on the lifter found its way into the oil pump. The engine was full of metal bits off the push rods. With the 1.6 you may also have clearance problems in the head and the valve covers. As others have mentioned, you won't get much benefit from this change alone other than bragging rights. Save your money until you can get a decent cam and make the swap, you will get far more 'bang for your buck'..
Unk
In that case yes you can install them but not sure if much benefit on an otherwise stock engine.
I spent a few hours doing searches on the roller tip rockers: I put a set of NON-Rollers on my 1992 350 cu.in. engine a few years ago...50,000 with no problems.
1. They will add a little pep to the engine..similar to a good tune-up (Do the tune-up first)
2. Be careful which manufacturer you buy from--they advertise 1.6 BUT they may be 1.55 or less 1.35
3. Watch out for rubbing pushrods as other members said.
4 . FOLLOW THE RULES about installing the new rocker arms to avoid the valves hitting the tops of the pistons
4. It;s probably just me, but I would remove the 12volt supply to the distributor and crank the engine a few times until engine oil was visibly coating the valve train., which also ensures the lifters are pumped up with engine oil.
5. MAKE SURE the rollers are centered on top of the valve stems (another member had a roller rocker ruin the top of a valve stem)
6. Then I would reconnect the distributor and start the engine.....readjust the rockers as needed.
SOMEONE CHECK THE OUTLINE ABOVE FOR MISTAKES / FORGOTTEN STEPS, PLEASE.
Can I install 1.6 roller rockers in my 82 corvette 350 crossfire engine stock cam without running into any major problems ?
yes you can, but you will need to
check a few things. You need to
make sure the springs can handle the additional Lift. You also need to make sure there will not be any coil bind with the springs. You could be limited in spring selection and coil bind by the spring pocket and valve seal.
So, all the roller tip rockers, of any brand, are a true 1.52 or 1.6 ratio, and all the factory rockers very a great deal?
How about aftermarket non roller tip?
If you use good factory or aftermarket rockers, how much do you expect to gain with a roller tip vs conventional rockers?
Not only do stock rockers vary greatly, they flex a lot, especially at higher rpms. Which decreases lift also, and then there is the friction loss added in.
I am not familiar with the roller tip, but I know the 1.6 ratio helps.
Do you know the "feel" when the A/C compressor turns Off while driving on the interstate?
It is as though the car instantly gained another 10-15 horsepower.
After installing true 1.6 rocker arms you get a similar feeling taking off from a complete stop.///a little more pep for the dollar.
Removing the intake manifold and trimming the gasket openings to get better airflow will give the same results "on top of" the rocker arm modification. My rookie experience is the engine will actually idle approx. 150 rpm faster once the trimming is done.
Use the 1.6 Comp Magnum rocker......but use them with Poly-Locs.....much easier to lash.
You will see some benefit but not much until you get rid of the factory intake manifold.......it is a cork, and until the engine can breathe, most upgrades are futile.
