Basic Rear Toe-in Question
Old Feb 12, 2021 | 12:03 PM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
Default Basic Rear Toe-in Question
A rather basic question, but one I couldn't find an answer to in previous threads....
What difference the does addition of trailing arm shims make at the wheel. where I'm looking to get about 1/16" or 1.5mm toe- in at each.The shim sets come with three size shims, basically, thick, medium and thin! What change would a thin shim make, in mm (or fractions of an inch), does anyone know, please?
A "starting point" would be handy!
Thanks!
Old Feb 12, 2021 | 12:27 PM
Mooser's Avatar
Mooser
For me
A 1/32" shim moved from one side of one arm to the other changes my readings at the front spindle by about .335 difference from one side to the other or about .167" from the centerline at the front spindle of the car
M
Old Feb 12, 2021 | 05:12 PM
ramair_bryan's Avatar
ramair_bryan
Always depended on the size of the fat chick potential in the right hand seat.......................
Old Feb 12, 2021 | 06:01 PM
gkull's Avatar
gkull
I'm not saying that this is the best video, but I worked at a race shop and I had to do C3 vette rear alignments more often than I wanted to. We actually had the laser optical read out with bolt on attachments. As to you question I never found a direct relationship from shim width to toe being a one to one because of the distance. Then you are changing things slightly when pull out one from one side to insert it to the other. It was always a trial and error. I never took the time to figure out exactly how much each shim actually moved the toe. Maybe someone on here does this for a living. I might have done only a few a year and it was always in a hurry.
Use stainless steel shims only!
Many years ago I came across adjustable rear toe setup and I told the boss about them. They could only be installed if you had the body up or off enough. So it was more a racing vette idea. But once installed they were great. In cold weather we could easily add more rear toe in to keep heat in the rear tires down long straights.
Old Feb 12, 2021 | 06:34 PM
cagotzmann's Avatar
cagotzmann
Thanks!
Here is my complete DIY alignment method.
First step for changing your rear shims is to get the rear thrust angles correct then adjust for total toe.
My DIY Alignment method - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Feb 12, 2021 | 08:16 PM
kansas123's Avatar
kansas123
(43) How To Do A Rear Wheel Alignment (Part- 1), on a C3 Corvette (Part 1 of 2). "Corvette Hop" - YouTube
I like this guy's method but man I hate to think about removing the dadgum callipers. I hate to even breath on the brakes lol. Forward march!
To Basic Rear Toe-in Question
