temporary fix for leaking steering gear box
Old Feb 25, 2021 | 08:01 PM
vince vette 2's Avatar
vince vette 2
Default temporary fix for leaking steering gear box
OK, I know this ain't the way to do it. But the clock is ticking on my 4L60e transmission swap warranty as the intall took way longer than planned. And I really need to get some miles on it to ensure everything is OK before the warranty is up. I figured the oil I saw on the steering box was just like all the other oil under the engine, but it appears to be an actual leak in the box. Can something be tightened to slow it, more grease put in, etc. I'd just like to be certain to get a few hundred miles out of it. For the record, the car is an '80, 90k miles, original steering box.
Old Feb 25, 2021 | 10:24 PM
GTR1999's Avatar
GTR1999
Vince
There should be no oil in the steering box. There should be grease and the problem with old boxes is the grease has turned into an acidic sludge. The oil separates out and once that happens it is going to get by the seals- new or old. The boxes are not vented and close to the exhaust which adds to the problem. They will leak from the upper and lower seals. Now if you added oil in the past that changes most of what I just said other then the leaks will stay in the box until you get the box cleaned out , resealed and greased at a minimum. To go through all that to just change seals though doesn't make sense.
Old Feb 26, 2021 | 05:42 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Old Feb 26, 2021 | 05:43 AM
ralphspears
Banned Scam/Spammer
Steering gear lube
Old Feb 26, 2021 | 08:20 AM
vince vette 2
Originally Posted by GTR1999
Vince
Gary, thanks for the explanation of what's actually happening here. Basically if I understand your comment, what I would need to do to get some new grease into it would be the majority of the work needed to rebuild it, which I plan to do. But I just find myself in a situation where right now I need to drive it at least enough to verify the transmission if functioning OK, and not just 10 or 20 miles which won't prove much. I guess the question is do I risk damage or worse driving it for perhaps 100 miles before tackling the steering box rebuild? In answer to your question about servicing it, it has never had any service in its 90k miles. As you may recall from our past conversations I'm the original owner of the car.
Old Feb 26, 2021 | 10:12 AM
GTR1999's Avatar
GTR1999
Vince
100 miles isn't going to make a difference. If the gears or the end of the ball screw is acid etched now 100 miles isn't going to cause it to lock up. I have had boxes shipped to me that had no grease in them and so much wear the car was aimed not steered. In your case I would wipe it down, do your testing and then rebuild the box the correct way and be done with it. You could do the add grease method of removing cover bolts but that isn't the best way. If you remove the cover you will change the lash so it will have to be set close on the car, again I would drive it for now.
Old Feb 26, 2021 | 11:36 AM
vince vette 2
Gary,
Thanks for the guidance
Old Feb 26, 2021 | 12:17 PM
Sayfoo's Avatar
Sayfoo
From my experience, the statement about no oil is correct. Some/most grease's will separate and the light weight oil will leak easier.
If you have some kind of suction device you can suck out the oil through a bolt hole in the top cover and inject some grease.
My steering box gets real hot and the increased pressure made the leaking worse.
I drilled a small hole through the center of the highest bolt on the top cover to vent the box, and eventually, the grease level stabilized and the leaking stopped immediately.
It did puke grease through the hole until it got to a point that the hot grease wouldn't expand and ooze out.
Old Feb 26, 2021 | 01:23 PM
domenic tallarita's Avatar
domenic tallarita
When I rebuilt my box I put very thick oil in it thinking it would be the way to go. The rebuild went perfect and the body was not on the frame. I noticed oil on the floor under the box and it just kept coming out. So I got on the forum and I think it was Gary that mentioned a grease from auto zone.
So I removed one bolt and machined a hole thru another bolt, welded a air fitting on the bolt and attached a air hose with about 130 PSI to push all the oil out. Not 1 drop would come out when under pressure. Take the air away and it would leak, with air no leaks.
Well the air forced the seal against the shaft and no leaks. With no air the seal relaxed and leak came back.
I have seen this many times on aircraft struts that have 500 + PSI over hydraulic oil. The struts would leak hydraulic oil when the Nitrogen PSI was low. Many mechanics rebuilt the struts and I found that in most cases the struts just needed pressure added to keep the seal.
So getting back to my steering box, the air pressure made the seal work better.
Dom
Old Feb 26, 2021 | 02:55 PM
GTR1999's Avatar
GTR1999
Dom,
The grease I used to get was Coastal but it was changed or sold and the grease I used to use disappeared years ago. I use Lucas HD Green now. As mentioned all grease will have a drop point and a good indicator is to open the tube or container and see if there is oil separated out.
The problem with an original 40 year old box is the grease has pretty much broken down. If Vince never put any oil in the box then what is leaking out is what is left of the original brown pasty 1980 grease GM used. Once all the moisture is gone then corrosion will start to set in and it will be down hill from that point on. Trying to result a box at that point is usually not going to improve anything in it. For cars that sat for a very long time, corrosion will eat into the teeth that have been meshed for years. If the steering wheel was turned to one side that would be positive, if stored with the wheel straight and corrosion starts the gears will be wrecked for sure. When I blueprinted one of the original 63 grand sport boxes the car was stored with the wheels turned and that saved the gear set since corrosion wrecked the tooth contact patch but the straight away contact was perfect still and those were one of a kind faster ratio never offered in a production vette.
Old Feb 26, 2021 | 11:51 PM
7T1vette's Avatar
7T1vette
Full-synthetic gear grease won't melt and run out of 'iffy' seals because of heat near exhaust dumps....
Old Feb 27, 2021 | 07:08 AM
vince vette 2
Guys, this is why I like this forum, great real world knowledge you'd have to dig hard to find. Reminds of the time after pulling the distributor cap, which got moisture in it, off a 76 Century, drying it out, and putting it back on the car wouldn't start. There was no spark even though there had been before. After several hours I called my grandfather who was a machinist and mechanic and had run his own garage for over 30 years. He told me to check one particular wire on the plug into the HEI. "The contact will back out when you try to plug it in", he said, "but not far enough to fall out of the housing". Sure enough, that was it. Gramps has been gone now for 30 years. But at least we have forums like this.
Old Feb 27, 2021 | 07:12 AM
vince vette 2
Dom,
Gary, based on this I'd say I'll be looking for a new box when this is over. I'll follow up on this thread next fall and let everyone know.
Old Feb 27, 2021 | 09:02 AM
GTR1999's Avatar
GTR1999
Vince you don't need a new box, you just need yours to be correctly set up with the right parts and procedures. This might be something you can do in your shop? If you have any questions when you get to that point let me know and I can go over them with you. A good dial 0-30 Tq Wrench is required.
Old Feb 27, 2021 | 09:43 AM
vince vette 2
Sounds good Gary. I have a generally good click torque wrench OK for lug nuts and heavy stuff and calibrated by the lab I work at. But, in this case I'll just ask to borrow one of their calibrated dial torque wrenches.
Old Feb 27, 2021 | 01:06 PM
domenic tallarita
Gary,
I have two 63 gear boxes and remember opening one up and saw what you described.
Are you still rebuilding them?
Dom
Old Mar 1, 2021 | 02:56 PM
TedH's Avatar
TedH
My steering box has looked greasy/oily for the last 24 years. I have one of those 'grease gun probe' attachments and that is what I would use to inject new grease into the inner reaches of the steering box. Then, button back up and enjoy it another 25 years.
If the steering is not exhibiting issues (loose), drive it like you stole it. Slave cylinder can groan but that is more an issue with the parts attached to the power steering pump than the steering gear box.
To temporary fix for leaking steering gear box
