Exhaust Donut
Old Mar 4, 2021 | 07:44 PM
PurePearl32's Avatar
PurePearl32
Default Exhaust Donut
Got two questions for you guys regarding the exhaust gasket and donut on my 74 L48. I noticed an exhaust leak yesterday on the passenger side where the heat riser meets the pipe. Got the nuts off the studs fine, unbolted everything, and dropped the entire pipe. Found no gasket between the heat riser and manifold. I assume there should be one there? Noticed two different gaskets available too. One is for a 3 1/16" bolt hole center and another is for a 2 11/16" center. The 3 1/16" looks correct but I can take it to parts store to verify.
There is a donut between the pipe and heat riser. The donut is not soft but does not appear to be steel however as it is flaking off a lot. According to the factory AIM, there should be a donut sleeve that goes inside the exhaust pipe and the donut seals between there and the heat riser. I do not have that donut sleeve. I've read around the forums and there are a few posts stating if a steel donut is used, the sleeve isn't necessary. Is this correct or should I be ordering the sleeve? Thanks!
Old Mar 4, 2021 | 10:04 PM
carriljc's Avatar
carriljc
Follow this link. It explains why you want to have the sleeve and has drawings and whatnot. https://www.corvetteforum.com/forums...ust-donut.html
ah... here's the reason per Willcox. You wanna have it: https://www.corvetteforum.com/forums...post1598267224
Old Mar 4, 2021 | 11:16 PM
PurePearl32
That makes perfect sense, especially with the original asbestos(?) donut that I currently have. I'm sure the heat is what destroyed this one. I don't mind spending the 20.00 from Zip to get the sleeve, however I'm planning on using the following steel donut (https://www.oreillyauto.com/detail/b...+gasket&pos=29).
If the metal sleeve protects the packing on a 'soft' donut, am I incorrect in thinking I do not need the sleeve when using an all metal donut? Not trying to skimp anywhere, just genuinely curious if it's needed in my application.
Old Mar 5, 2021 | 12:19 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Use the sleeves no matter the donut material. They help create a seal by aligning everything and channeling exhaust gases. You might be able to find the properly sized pipe connector (sleeve) at OReilly's -- I believe I've seen them there for much less $ than the Corvette parts vendors. By also installing the triangular gasket between the riser and manifold it'll help seal the system. Just make sure the heat-riser valve (if your riser block has it) is functional after everything is buttoned back up.
Old Mar 5, 2021 | 09:52 AM
Tampa Jerry's Avatar
Tampa Jerry
Call your local muffler shop. They have the equipment to make up the sleeve while you wait. You can also get the donut at any well equipped parts shop like NAPA. The muffler shop should have a donut as well. Jerry
Old Mar 5, 2021 | 10:04 AM
augiedoggy's Avatar
augiedoggy
When I bought my 74 the original donuts were also also completely toast and the pipes were very loose as a result. I was not so lucky and snapped frozen bolt when trying to tighten despite the threads not being bottomed out. I ended up swapping to sidepipes in my situation which I wanted to do anyway. I could not believe the PO drove it that way.
To Exhaust Donut
