Removable Rear Window Conversion-Which Halos?
Old Mar 19, 2021 | 02:48 PM
Richard Daugird's Avatar
Richard Daugird
Default Removable Rear Window Conversion-Which Halos?
I have a '68-'72 window and latches in hand, hardware, gasket, etc. on order. I am replacing most of my interior as it is in bad shape. I understand the "Halo" panels were different every year, and since I am buying new ones, I can get whatever year I want. The 68-69 need separate bezels around the latches, so I've ruled them out. My car is a '74.
Old Mar 19, 2021 | 02:53 PM
walleyfisher's Avatar
walleyfisher
I did put the 72 removable rear window in my '74, I purchased the (2) upper side panels with bezels, the handles, and the (2) lower pin alignment bezels ( from a bone yard), everything bolted right in with no modifications need except had to dye the plastic Med saddle to match my interior
Old Aug 1, 2021 | 04:24 PM
'75's Avatar
'75
I realize this thread is a few months old, but I'm doing this job to my 75. Seems the holes for the latches aren't drilled. Do they use u-nuts? What size are the screws?
Old Aug 1, 2021 | 04:41 PM
DC3's Avatar
DC3
I've attached a couple of files I found when I converted my '73 back in 2008. Maybe they'll help. It's been too long for me to know the answer to your question but hopefully someone else will remember or you can find the answer in these files. Some of the pics in the files are missing because I didn't realize they were links and over time the links were broken.
File Type: pdf
To Removable Rear Window Conversion-Which Halos?
