82 with fan/blower issue
Old Apr 14, 2021 | 05:11 PM
ESU's Avatar
ESU
Default 82 with fan/blower issue
Developed an oil leak a while back and with some warm days I decided to replace the valve cover gaskets. Not as easy as I would have liked, Alt and smog stuff had to be moved and the covers wrestled off etc. Anyways, start the car today to burn off and fluids that leaked and see if there are any other issues when I notice my fan isnt working. Not on any speed or any setting, a/c, heat etc. Figured maybe i jostled something and blew a fuse. I dont see any fuse in the fuse block diagram that indicates blower motor? Checked one or two anyway but they seem good and most other electronics seem to be working. I took a look at the blower motor itself and it seem there are 2 electrical connections, a single one on top and one lower. The top one has a wire connected, the bottom doesnt? I also have two wires in the vicinity that are loose and not connected to anything, 1 is black and 1 is a heavier purple one. Any ideas or thoughts? Thx, Cory
Old Apr 14, 2021 | 05:54 PM
interpon's Avatar
interpon
i would start here..
1978-1982 Corvette- Understanding the high blower relay. | Willcox Corvette, Inc.
Old Apr 14, 2021 | 06:15 PM
ESU's Avatar
ESU
first off where is it located? And I dont have any speeds let alone hi.
Old Apr 14, 2021 | 06:20 PM
interpon's Avatar
interpon
https://www.corvetteforum.com/forums...ng-on-a-c.html
https://www.corvetteforum.com/forums...t-working.html
Old Apr 14, 2021 | 06:47 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
For an 82, here is where the high blower relay is located.
Old Apr 14, 2021 | 07:49 PM
ESU's Avatar
ESU
that was clicking when I played with the fan switch
Old Apr 14, 2021 | 08:03 PM
ESU's Avatar
ESU
Looks like this is actually under the blower motor, should something be connected to this? Would it be either the black or purple wire that are unattached to anything now. I guess I could have tugged on a wire when pulling the valve covers.
Old Apr 14, 2021 | 08:12 PM
interpon's Avatar
interpon
Yes..black ground/ purple power
ground should screw to screws holding fan in.
at least on a 79
https://www.corvetteforum.com/forums...d-working.html
Old Apr 14, 2021 | 10:26 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
Yes like interpon stated, black is ground and purple is power. The ground should go to a male spade terminal mounted on one of the blower motor mounting screws. The power wire, purple wire, should have a round rubber boot on it and plugs on to the terminal with the round part on it that you show in your picture.
Old Apr 15, 2021 | 09:02 AM
ESU's Avatar
ESU
I have a heavier gauge purple wire just laying loose in the area so I guess I pulled that out. My concern is that when I put a test light to it there is no power there.
Old Apr 15, 2021 | 09:26 AM
interpon's Avatar
interpon
verify test light ground and fan ground.. put blower in high (should send full voltage to fan which is the click in the relay)
also i find it strange that you could have pulled the wire from doing valve covers? that wire is not easy to get too.. but if it was working fine before...?
Old Apr 15, 2021 | 03:49 PM
MattoonVette
Just test the circuit like interpon stated above. Does your purple wire have a round rubber boot on it?
Old Apr 15, 2021 | 06:25 PM
ESU's Avatar
ESU
doesn’t have a rubber boot more like a plastic connector but I plugged it in anyway and it worked. No idea how the heck I unplugged it. Thanks to all
Old Apr 15, 2021 | 07:24 PM
MattoonVette
Interesting on the no boot. Here is what I have on mine. This plugs directly onto the fam motor that has the round housing on it. Like the one in your picture.
Old Apr 15, 2021 | 07:41 PM
ESU's Avatar
ESU
To 82 with fan/blower issue
