door locks
Old Apr 20, 2021 | 10:15 PM
Massive Legend Here's Avatar
Massive Legend Here
Default door locks
I'm having an issue where the keys don't lock the doors. They will fit but I cant move them to lock the car. The lock cylinder also will jiggle a little bit so I'm wondering if it's disconnected but idk what I'm looking for in the door.
Old Apr 21, 2021 | 01:02 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Won't lock or unlock either door? Sounds like you have the wrong key.
Old Apr 21, 2021 | 02:13 AM
Bikespace's Avatar
Bikespace
Do you have both keys? The ignition key is square, locks are round. GM alternated lettered pairs for many years into the 80s, so you'll need an A and B key, or C and D key, etc. In my 79, the power door lock actuator siezed in one of the doors and prevented manual actuation. After I replaced it, and greased the mechanism, the manual locks (and power) worked normally.
Don't need keys if the windows are down and the T-Tops are off.
Old Apr 21, 2021 | 05:30 AM
Plasticexperience's Avatar
Plasticexperience
In my 69 it’s very simple. You have a pawl on the back of the lock that slides on to the door lock lever. When you turn the key it simply moves the lever-It wouldn’t be probable that you have issues with both door loch mechanisms - thus I second post #1’s comment.
Old Apr 21, 2021 | 09:46 AM
interpon's Avatar
interpon
also on yours..turning left on drivers door sets alarm..
took me 2 weeks to figure that out..let's just say i found the extra horn and the plug.
it is helpful to post year in your questions fyi.. 79 L82
Old Apr 21, 2021 | 10:32 AM
Dagious's Avatar
Dagious
What year is your Vette. In early C3’s the square ignition key was also used for the door. The oval was for the glove box and tire lock.
Old Apr 22, 2021 | 06:48 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If they are the correct keys for the doors then the mechanism could be just full of debris. If thats the case flushing it out with penetrant can greatly improve it if you dont want to remove them to clean them. Just get a good penetrant and use the red straw, push it into the key hole and flush it out. Use the key to jiggle the inards and repeat. If its seized the penetrant will help to get the parts free. I like PB blaster.
Old Apr 23, 2021 | 02:26 PM
7T1vette's Avatar
7T1vette
Yep. Many years of service without additional lubrication will make door lock mechanisms gummed-up and sticky. Eventually, the resistance in the lock mechanism will be enough that the linking rod will bend and nothing will happen. You just need to remove the door panel and shoot some cleaner into the lock mechanism to free it up. Then put some fresh white lithium grease in it to re-lube. Work the lock with the key (Lock - Unlock) several times to get everything working well again. Now, you're good for another 20 years.
Old Apr 23, 2021 | 02:34 PM
Eric P's Avatar
Eric P
I had two bad lock actuator causing my door locks hard to turn with the key and hard to operate manually too but yours sounds like it needs the cylinder lubed up with some WD40 or something
To door locks
