Engine noise
Old Apr 25, 2021 | 05:22 PM
Massive Legend Here's Avatar
Massive Legend Here
Default Engine noise
Im thinking its the compressor but im not sure.
Old Apr 25, 2021 | 07:39 PM
forman's Avatar
forman
could you make it a little longer ,, talk about quick ,,, sounds like a pulley bearing somewhere
Old Apr 25, 2021 | 07:56 PM
Mrvettenick's Avatar
Mrvettenick
Gun to my head.......water pump.
Old Apr 25, 2021 | 09:18 PM
derekderek's Avatar
derekderek
could be alt or power steering. but it is the water pump. pull off one belt at a time and run it.
Old Apr 25, 2021 | 09:50 PM
interpon's Avatar
interpon
Or air pump or..ac clutch or........
go to harbor freight..be careful...get that stethoscope...you will know which in short order
edit.. sure looks like ac smoking and sticking.. is the ac on? pull the wire to compressor and take longer video from side front
Old Apr 26, 2021 | 07:39 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
always use a stethoscope or a screwdriver stuck in your ear before taking things apart. Best not to waste your time just blindly attacking your motor
Old Apr 26, 2021 | 08:36 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Handle against the ear....I bet.
Old Apr 26, 2021 | 08:52 AM
Rescue Rogers
Ohhh, that would be more comfortable...good point!!! I can always rely on Tony for a quick smile....lol
Old Apr 26, 2021 | 12:23 PM
Sayfoo's Avatar
Sayfoo
Take your belts off one at a time to try to isolate the problem.
Old Apr 26, 2021 | 06:09 PM
Massive Legend Here
Thank you guys for the help I also got a better video that shows the problem It looks like the thing in the front right isn't spinning and the belt is just being pulled around it.
Old Apr 26, 2021 | 06:45 PM
drwet's Avatar
drwet
https://youtu.be/kwoG0tcSthE
Didn't need to stick a screwdriver in my ear to figure that one out. I think it's safe to say your compressor is seized.
Old Apr 26, 2021 | 06:53 PM
interpon's Avatar
interpon
Lol
op
do not run until
pull those wires off compressor and seeif it smooths out...
if still seized removethat belt...take some pics of your engine / belts..
if lazy and assume belt shot...just cut it out unless removing wires fixes it.
the wires engage the clutch on the compressor if on and you have freon.
And try it
Old Apr 26, 2021 | 09:27 PM
Massive Legend Here
@interpon Disconnecting it did fix it what does that mean then?
Old Apr 26, 2021 | 10:11 PM
interpon's Avatar
interpon
my guess is that you had the ac on inside the car?
that wire powers the clutch to engage compressor...
you have a nice original car...
my guess is unless the ac was converted you have a system that still has freon..maybe r12 or not..or who knows...
My guess is your compressor is seized.
edit....told ya...you are me two years ago identical cars lol..here ya go
https://www.corvetteforum.com/forums...s-oriface.html
https://www.corvetteforum.com/forums...2-ac-help.html
https://www.corvetteforum.com/forums...questions.html
Old Apr 26, 2021 | 11:39 PM
Massive Legend Here
@interpon So does the compressor unplugged just affect the ac in the car? Also, the whole car is original the only thing ever done to it was tires once and the engine got new seals in 96.
Old Apr 27, 2021 | 01:27 AM
derekderek's Avatar
derekderek
the clutch freewheels on the compressor when unhooked or shut off. you can see the clutch engage and force the compressor to go about 1/4 turn before it locks up and squeals. you should be ok as long as you do not run the ac.
Old Apr 27, 2021 | 08:33 AM
interpon's Avatar
interpon
yes only ac compressor.
add it to your list to get to when you prioritize projects.
tape the connector away safe
keep your eye out for r-12 if you decide to go that route.. i'm betting yours still was running it..i scored 7 pounds in central indiana..just keep eye out..or you may decide to convert.. another project when you get to it.. also post some more pics as needed!! don't be shy, many keen eyes on this site and helpful..
To Engine noise
Old Apr 27, 2021 | 01:00 PM
vince vette 2's Avatar
vince vette 2
Be a man, handle on the engine, point in your ear.
Old Apr 27, 2021 | 01:02 PM
vince vette 2
That ain't freon. All the magic smoke escaped.
Old Apr 27, 2021 | 01:11 PM
vince vette 2
What's a pound go for these days. I have just shy of 10lb. When I bought it I paid $2.97 per 12 oz can. Not looking to sell as I have my own 1980 with with an inop AC, but as it's way down the priority list it will be some time before I get to it. The only question is heater core or AC first.
