ARP Ring Gear Bolt Troubles
Old May 29, 2021 | 11:16 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Slow progress. But ring gear is on.
Each bolt had to be custom trimmed and measured. Roughly .060" shorter. Bolts are still longer than GM and 30% stronger!
Each bolt measured like this. This height needed to be LESS than the flange thickness
L to R: GM bolt, trimmed ARP, new ARP
Gear Installed
Old Jun 5, 2021 | 11:36 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Nice work. Fwiw, I fitted ARPs to a 3.36 gear without any problems - diff has done a lot of street and competition miles over several years before I pulled it to swap for a 3.7 - which I also rebuilt with ARP bolts without issue. The 3.36 is still sitting on the shelf as a spare. Good catch on your part, a combination of factors I suspect as you say.
