1971 Power Steering Ram Rebuild
Old May 21, 2021 | 04:42 PM
farmerdick's Avatar
farmerdick
Default 1971 Power Steering Ram Rebuild
I heard that a new seal kit is available for one end of the piston but is the knuckle joint on the other end repairable?
Richard
Old May 21, 2021 | 06:08 PM
forman's Avatar
forman
yes
Old May 21, 2021 | 06:57 PM
7T1vette's Avatar
7T1vette
You can get a repair kit WITHOUT the replacement knuckle; and you can get one WITH a new knuckle. Select wisely, Grasshopper...
P.S. When making that repair, keep track of the order and orientation of the layers of seal materials you remove...so that you can [correctly] reverse the process when you rebuild. Also, take care NOT to scuff, scratch, or damage the outside surface of the apply rod.
Old May 21, 2021 | 07:23 PM
farmerdick's Avatar
farmerdick
thank you gentleman. thats what I needed to know.
Old May 22, 2021 | 06:19 AM
V4motorsports's Avatar
V4motorsports
This might be of help:
Russ
To 1971 Power Steering Ram Rebuild
