Drive Train Klunk
Old May 24, 2021 | 12:36 PM
captng1's Avatar
captng1
Thanks standardbyke22,
Not sure where the sunbreo bushings you are referring to live? Do you have a pic from a manual you can share?
Old May 24, 2021 | 12:37 PM
captng1's Avatar
captng1
Thanks Tampa Jerry. Going to have a look at all....
Old May 24, 2021 | 12:39 PM
captng1's Avatar
captng1
Thanks for sharing Rescue Rogers,
Great work and pics. I am looking into my snubber bushing and trailing arm bushings. I hope I find the problem...
Old May 24, 2021 | 12:50 PM
Hopper12's Avatar
Hopper12
Hey captng1, lots of good advice from the forum members, as usual. The following is your friend when trying to inspect all sorts of hard to reach/see parts: https://smile.amazon.com/Inspection-...NsaWNrPXRydWU=
BTW, the instructions for these always say 'not for personal inspection'.
Old May 24, 2021 | 12:54 PM
captng1's Avatar
captng1
Thanks Hopper12. Looks like a great machine...
Old May 24, 2021 | 10:02 PM
captng1's Avatar
captng1
Hi Tampa Jerry,
I got under the car to find that the snubber bushing is good, the trailing arm bushings are shot, as well as the strut rod bushings. The shims in the trailing arms are still tight. Not looking forward to trying to get those trailing arms off. I know they are a MF! My passenger side trailing arm has a bend in it. Is it supposed to be that way? Also the drivers side trailing arm appears to have been welded. See attached pics.
Weld on Drivers side Trailing Arm
Drivers Side trailing Arm Bushing
Drivers side Strut Rod bushing
Passenger Side Trailing Arm with bend. Is the bend normal?
Passenger Side Trailing Arm Bushing
Passenger Side Strut Rid Bushing
Snubber Bushing
Old May 25, 2021 | 12:54 AM
Peterbuilt's Avatar
Peterbuilt
Good job inspecting all the bushings and I agree they are all shot.
The snubber rubber does look OK but take a closer look near the arrow, is that a crack?
It looks similar to Rescue Rogers pictures.
Here's a list of most of the parts that have to be removed,
You might want to apply some penetrating oil for the next few days.
You will need a 3/8" pipe cap to remove the shock mount.
It's not that bad a job I did it 20 years ago and again last year after about 50,000 miles.
Old May 25, 2021 | 07:39 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I dont think those kinks and bends in your trailing arms are normal, especially with the need to weld in a plate on the drivers side. When you have them out you may want to consider having them inspected or replace them...guess its a good time to consider some offset trailing arms....
Old May 25, 2021 | 10:00 AM
Tampa Jerry's Avatar
Tampa Jerry
I see you are in South Florida. Consider using Van Steel in Clearwater. They are local for me. Give Danny a call and he will set you up. It may be worth a 3-4 hour drive to bring everything to them. They have everything you need to refurbish the rear. Consider replacing the rear bearings if they are original or suspect. Jerry
Old May 25, 2021 | 10:15 AM
captng1's Avatar
captng1
Thanks Peterbuilt,
That is not a crack. It is a shadow that was created by the flash on my camera...
Old May 25, 2021 | 10:16 AM
captng1's Avatar
captng1
Thanks Jerry,
Are you referring to the rear wheel bearings?
Old May 25, 2021 | 11:08 AM
Tampa Jerry
Yes. You will be removing the trailing arms and the bearing carrier is in the trailing arm. Jerry
Old May 25, 2021 | 11:37 AM
  #33
captng1's Avatar
captng1
Thanks Jerry. look at the pic of my passenger side trailing arm. Is it supposed to have that bend in it?
Old May 25, 2021 | 02:14 PM
  #34
captng1's Avatar
captng1
Hi Rescue Rogers,
Dont really need offset arms as I do not plan to put wider rims and tires on the car. Apparently the slight bend in the passenger side arm is how the arm is manufactured...
Old May 26, 2021 | 09:19 PM
  #35
captng1's Avatar
captng1
Does anyone have an opinion on adjustable strut rods? They seem to be better than the original cam type adjusters...
Old May 26, 2021 | 09:41 PM
  #36
Rescue Rogers
I have a set and I can adjust my camber as I raise and lower the rear end height to get the tracking I want....much better than the cam set up
Old May 26, 2021 | 09:51 PM
  #37
Peterbuilt's Avatar
Peterbuilt
I have them and they work just fine.
To Drive Train Klunk
Old May 27, 2021 | 08:23 AM
  #38
interpon's Avatar
interpon
i have OEM non adjustable (poly energy )..and have no issues.. BUT it was VERY hard for me anyway to get the rods aligned to re assemble. i was going to buy another reasonable adjustable set recommended but they were out or for me big $. those look reasonable!
my learnings..
79 strut rod advice - CorvetteForum - Chevrolet Corvette Forum Discussion
Old May 27, 2021 | 09:09 AM
  #39
captng1's Avatar
captng1
Hi Interpon,
Yes, those are definitely reasonable
Old May 27, 2021 | 09:21 AM
  #40
captng1's Avatar
captng1
Thanks Rescue Rogers,
I think I'm going to buy a set. If you are often adjusting your ride height, I assume you are bringing the car to a shop for final alignment after you adjust?
