From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by ChrisLSx
I'd be very interested to see some pictures if you manage to find them.
I looked for an old weight loss thread here in C3 Tech. It's under the title 2780# something something and dated 7/27/2016. It's got some pictures of the radiator support and some other things. Search "aluminum radiator support" and threads by 69427, and it should pop up.
I'm not home, but it's like. 250 tempered aluminium. Hard to even drill through. We used it at the race shop io make front and rear motor mounting plates for tube frame cars
It's engineering is pretty good because it has withstood over 200 mph at Bonneville salt flats
I'd be interested in pictures too. Thanks for the ideas and insight
I posted pictures above. But 69427 has done the most amazing job of weight reduction and flat bottom for a Big Block Chevy. I really like that he went to the extent of even learning aluminum welding to fabricate his own custom stuff. Some people have the ability to envision things and make them work!
I just threw away the vacuum tank. Made an aluminium lower radiator support out of plate and angle. Relied on the original side brackets and bumper support (with a huge amount of weight cut out of them) to support the nose. I've actually had an accident since doing this - on a damp track, I put the nose straight into the end of a tyre barrier at ~80-90kmh (50-55mph). The car survived seemingly unharmed, except the front of the car was sitting too low and the hood wouldn't open. It bent my heavily lightened side brackets supporting the nose and flexed the whole nose of the car down. I drove it home, unbolted the side brackets and the fibreglass popped straight back up. Straightened the side brackets, and bolted it all back together and it's been fine since... That was several years ago. I think that's reasonable proof that my method retains adequate strength, I actually think I unintentionally built a bit of a crumple zone into the front. I suspect that if I still had all the factory brackets there that it would have done a lot more damage, as there wouldn't have been anything to "give".
I put the nose straight into the end of a tyre barrier at ~80-90kmh (50-55mph). The car survived seemingly unharmed, except the front of the car was sitting too low and the hood wouldn't open..
You are lucky! I was going closer to 140 Kph and an object the size of a 5 gallon bucket came off the vehicle in front of me that I was going to pass. I just punted the debris off the track and didn't think much of it and kept driving. In the pits I saw a crack from the front to the top of my passenger fender. I never did find out who's car it was or what body part came came off.
Great thread. But you should have also removed the brakes.......those will only slow you down!
I noticed in the thread you used to venture out to Heartland Park, are you in that area of the country? It's local to me
I'm just over the border. I used to go to HPT quite regularly, but haven't been able to get back there since they opened up again. I'm hoping to get there sometime this summer. My avatar picture was taken several years ago at HPT.
Hmm, I wasn't really thinking about weight reduction on my BB, but it would be easy for me to fab everything up in aluminum to replace those heavy parts. Do they all unbolt? I would want to make sure I could return it to stock someday since it's a very clean original car.
Pretty much anything that's metal unbolts from a Corvette. Mine's a numbers matching car too, so I just put the cheap heavy stock parts on a shelf in the garage and make or substitute as many aluminum parts as I can. A coat of semi-gloss black paint on most of the replacemnt parts, and the car looks pretty stock.
