Speedo Question
Old Jun 16, 2021 | 03:30 PM
GX Ame's Avatar
GX Ame
5th Gear
Default Speedo Question
78 with automatic transmission. At slow speed the needle barely moves. With car at 50 mph, the needle waivers around 30 mph but goes no higher. Not sure if it would be the the speedo cable or the gauge itself. Any help would be appreciated. Thanks.
Old Jun 16, 2021 | 06:05 PM
Mrvettenick's Avatar
Mrvettenick
If you're sure the cable is engaged at both ends, Cable problem would be no operation or an oscillating needle. Sounds like the speedo. They can be cleaned up and repaired.
Old Jun 16, 2021 | 08:44 PM
MelWff's Avatar
MelWff
Remove the cable at the transmission end. Spin the cable with a drill. Same issue, it's the speedometer. Otherwise check the driven gear in the transmission.
Old Jun 16, 2021 | 08:49 PM
7T1vette's Avatar
7T1vette
Yes. Sometimes the square-drive recess in the trans gear can get cracked so that the cable will work OK at low speeds, but start to slip and spin inside that recess at higher speeds.
Old Jun 17, 2021 | 04:50 PM
GX Ame's Avatar
GX Ame
5th Gear
Thanks for the replies. I'll check it out.
Old Jun 17, 2021 | 05:17 PM
vince vette 2's Avatar
vince vette 2
Be careful with the driven gear - it's fairly easy to push it in too far and have it drop into the transmission tail assembly. Then after a few hours of trying to fish it out, just put another one in. It doesn't seem to bother the tranny any to have the other one floating around in there.
To Speedo Question
