Electric Light Popups
Old Jun 25, 2021 | 04:21 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Me, fairly big cam for the street. 11.5 inches of vacuum. Headlights work fine with the vacuum system. Super easy system to repair if it does act up.
Old Jun 25, 2021 | 07:41 AM
derekderek's Avatar
derekderek
now that the bug debris is out of my vac lines, i can raise or lower one headlight by sucking on the hose. (no chrome off trailer hitch jokes please.) surprised me. i was checking to see it it leaked and up it came! that is not but about 3 inches of vacuum tops. the control relays require a bit more, but not much.
Old Jun 25, 2021 | 10:31 AM
76-Vetteman's Avatar
76-Vetteman
I will be moving to an LS generation engine soon. And during this build I will upgrade the headlight actuation system to electric, and the brake system to hydroboost.
For me, it is not about the money. My reasons for newer systems are simple. 1) To improve the drivability and reliability of the Corvette. 2) To eliminate ECM control problems by eliminating vacuum leak sources. 3) To minimize the necessary components, hoses and wires.
Old Jun 25, 2021 | 12:16 PM
OldCarBum's Avatar
OldCarBum
Wow, I didn't think of this.
I could have just run a single rubber hose up to the drivers seat to keep the headlights up and saved some $$$.
Now you tell me!
Old Jun 25, 2021 | 01:18 PM
Kidster71's Avatar
Kidster71
Highway Man
My 71 coupe was ridden hard and put away wet and was literally sitting in a barn for ~20 years till I rescued it. My instincts told me to run like hell but it was so cheap, had very little rust, a no hit body and I was looking for a new project. I have old Triumph motorcycles that are original and one of the three has the factory paint. I respect and enjoy bone stock classics but this one was a base model with a million things wrong with it so it wasn’t going back together stock other than the look.
Most of the vacuum hoses, actuators, switches, etc. were broken and or rotted and I was thinking performance motor that might not have much vacuum. Removing it all reduced weight and to me, unsightly look of the hoses draping around the engine bay. I went HydraBoost for brakes as well.
The only vacuum that I need now is for the vacuum referenced fuel regulator for my EFI and my charcoal canister for fuel tank venting.
Cheers,
Richard
Old Jun 25, 2021 | 02:48 PM
DC3's Avatar
DC3
Originally Posted by 7T1vette
IMO, going to electric actuators is a waste of time, money and effort...
P.S. You did ask for input. I just thought you ought to hear both side of the issue.
Apparently you think any modification someone wants to do to their car is a waste of time, money and effort, UNLESS it's a modification you've made yourself. You continue to show your disdain for people who want to modify their cars. Just remember this: NEED has nothing to do with it.
He asked for input on electric conversion kits, not a diatribe on why you think he is stupid for wanting to modify his car.
DC
Old Jun 25, 2021 | 03:40 PM
wendellp601's Avatar
wendellp601
DC
In fairness to 7T1vette, the original post asked "What you guys think of the electric conversion kits for the pop up lights."
However, there are many members here that frown upon most anything that departs from OEM condition.
In the context of the original post "Red Dick" is dealing with a 1975 model that has been sitting for years.
The unknown condition of the vacuum system and the potential time / expense of rehabilitation could be driving his interest in electrification.
To me, there seems to be far fewer potential failure points in the electric conversion.
To name a few:
No more dry, cracked vacuum hoses.
No more dry, cracked diaphragms in the relays or actuators.
No more pinholes in the vacuum tank.
I'm all for any owner doing whatever they think they can in order to keep another one of these cars on the road and out of a barn.
If he's more comfortable with wiring than vacuum hoses, its no skin off my nose.
Old Jun 25, 2021 | 10:02 PM
7T1vette's Avatar
7T1vette
Actually, he asked what we thought about converting to electric actuators on the headlamps. And I wrote what I thought about doing so. And my thinking has nothing to do with making modifications on the car. I just don't like modifications that cost more money, take more effort, and achieve nothing over the stock system already in place.
Old Jun 30, 2021 | 10:28 PM
reddickracing's Avatar
reddickracing
Update, I went with Richard454’s latest electric kit. It’s as much plug n play as u can get. American made with superior parts. Can’t wait to get it on. Thanks everyone for the input.
Old Jun 30, 2021 | 10:34 PM
Kidster71's Avatar
Kidster71
Highway Man
You won’t regret it
Old Jun 30, 2021 | 11:42 PM
theandies's Avatar
theandies
Although always intrigued to convert my headlights and wiper door to electric my vacuum system works very good so I just don't have the desire to do the conversion and I can use that money for other projects.
Since your car has been sitting for a while I'm sure it would take just as much work getting the vacuum system working as it would just installing the electric kit. Not to mention all the new vac relays and actuators are probably made in China and will only work for a while. You made the right choice. While your messing with your headlights you might want to consider putting relays to control the lamps themselves. Richard can help with that as well and it gets the high current draw out of the headlight switch which to me is a fire hazard.
Old Jul 1, 2021 | 12:18 AM
OldCarBum's Avatar
OldCarBum
Excellent choice for Richard454’s kit.
