Turn signals
Old Jun 26, 2021 | 11:10 AM
Dane4444's Avatar
Dane4444
Cruising
Default Turn signals
Turn signals
need help
ive wired LS and radio and add on cruise but having a rough time with the turn signals
thanks
Old Jun 27, 2021 | 08:02 AM
henrikse's Avatar
henrikse
not sure what you are asking?
Old Jun 27, 2021 | 08:25 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Your profile says you have a 78. you may want to mention that when you have a question. Also, other than a rough time. what is your issue?
Old Jun 27, 2021 | 08:53 AM
Dane4444's Avatar
Dane4444
Cruising
Thanks for replying and Thanks for the tip. I have a 78 anniv edition. I installed lq4 and 4l80e and all the other happy stuff. The signals work when I pulled it in the shop. I seem to have power where I need it . No flash.
Old Jun 28, 2021 | 12:10 PM
7T1vette's Avatar
7T1vette
Did you attempt to tie any of the new power lines into the turn signal power source? If not, I suspect the 'work' under the dash has disturbed some wiring OR your turn signal flasher module (behind passenger dash pad at lower-right on my '71) has bit the dust....
Old Jun 29, 2021 | 05:08 AM
Dane4444's Avatar
Dane4444
Cruising
i’m no longer using the Printed circuit
would the turn signal indicator bulb be in series to complete the circuit
Old Jul 12, 2021 | 09:30 PM
Dane4444's Avatar
Dane4444
Cruising
I finally got it. I made a pin out harness for bulkhead connector and fuse box. That way I could work with fuse box in my hand versus being under the dash.
I traced back via schematic and power probe. Located problems and corrected in about 4 hrs.
To Turn signals
