1975 Voltage Capacitor Mounted To Steering Column
I just re wired my 75 and while I was removing the old harness I snapped the wire on this capacitor, but I have no idea where I can buy a replacement for it.
Ive been searching for months. all I can find are female or other connection types but I've yet to find the capacitor with a Male connector to plug into the brown wire under the steering column.
Thanks for your help!
You already have the Male housing you would just need the crimp terminal.
Damn that stings, im in Canada, with exchange and shipping thats gonna hurt.....
The vettes were prone to RFI ( radio Frequency interference) the problem stemming for the fiberglass did not act as a Faraday cage like the steel cars.Using capacitor across a contact ( Ignition switch/brake switch- couple examples) slows down the rapid change in current/ and or arcing when the contact is opened/closed.
The slowed change in current through the connection results in a weaker magnetic field around the conductor and therefore less radiated interference.
Vettes used the metal shielding around the ignition wires to eliminate that source of noise- but with new designed sparkplugs and wires that issue is greatly eliminated.
