Converting from auto to 5spd question
Old Jun 30, 2021 | 11:07 PM
simon60's Avatar
simon60
Default Converting from auto to 5spd question
Can someone direct me to a thread on 5spd conversion. My search skills aren't working apparently.
Old Jul 1, 2021 | 07:40 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You will have to dig through this pile. They dont let you use numbers in the searches apparently
https://www.corvetteforum.com/forums...rchid=85037018
Old Jul 1, 2021 | 06:45 PM
68/70Vette's Avatar
68/70Vette
Cliff's notes:
I bought a Tremac 5 speed configured with the shifter in a C3 correct position. You have a removeable auto transmission crossmember so this greatly helps with transmission install. If you've a 3.73:1 or numerically higher differential, the Tremac is easily the way to go. For a 3.08:1,or lower, you'll need a Richmond 5 speed. My opinion about diff gearing. Opinions may differ..
Need to have a frame fitting welded to the frame to support the "Z bar".
Installing the clutch support mechanism on the inside of the firewall will just be sooooo much fun,
Old Jul 1, 2021 | 10:55 PM
simon60's Avatar
simon60
Thanks I have a 3.36:1
Which one do you recommend
Old Jul 1, 2021 | 10:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
Use a hydraulic throwout bearing/clutch master
Old Jul 2, 2021 | 01:28 AM
68/70Vette's Avatar
68/70Vette
It's your decision, I'm partial to the Tremacs. They have a nice shift feel with short shift throws. They use the same gear shift lever of a standard factory C3. Heres the gear ratios for the TKX-5 speed
Wide Ratio: 3.27, 1,98, 1.34, 1.00, 0.72
Close Ratio: 2.87, 1.89. 1.28, 1.00, for 5th gear you get a choice of 0.68 or 0.81
Don't know what Muncie you have now, but it could be a M20 wide ratio, which is a common Muncie sold up until 1975.
M20 Wide Ratio: 2.52, 1.88, 1.46, 1.00
The close ratio TKX-5 speed gear ratios pretty much approximate what I'd guess is your present Muncie in the first 4 years and then gives you an overdrive in 5th. In 5th gear, you get a choice. For a 3.36, The 0.68 option gives you an effective rear end of 2.28 (not acceptable) or the 0.81 gives you an effective rear end of 2.72. The effective diff ratio of 2.72 gives you an cruise rpm drop of 20%.
The wide ratio 3.27 gives you a more effective launch rpm, but I think the cruise overdrive ratio (5 gear) may be numerically too low. Since the Muncie approximates your current tranny in the first four gears, and gives you a nice 30% drop in cruise rpm. Maybe you'd like this. But it's your choice.....maybe some other readers have an opinion.
https://shiftsst.com/blog/post/1968-...ctfit-kit.html. Talk to Silver Sport about a recommendation.
Old Jul 2, 2021 | 09:40 AM
augiedoggy's Avatar
augiedoggy
He has an auto now judging by the title of the thread.. No muncie unless im missing something.
Old Jul 2, 2021 | 10:11 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
If you go with a Richmond you might want to look into using a Long's shifter instead of a Hurst. It is pricey, but it was a huge improvement.
https://www.gforcetransmissions.com/...peed_Trans.pdf
Old Jul 2, 2021 | 11:15 AM
simon60's Avatar
simon60
Yes I currently have the stock TH400 and thinking of making it more fun to drive without making any irreversible changes.
I hope silver sport can help me with the gear ratios. Seems like a complete kit is the way to go with hydraulic clutch cylinder add on
Old Jul 2, 2021 | 12:15 PM
gkull's Avatar
gkull
I bought the complete kit for under $5000. With upgrades like blow proof bell housing, block saver plate, 22 pound SFI steel 168 tooth flywheel, 11 inch clutch, easy on the leg 1100 hp clutch/pressure plate. chromemoly drive line with billet main caps.
i advice against Hydro assisted clutches. It ruins all the petal feel and it's another failure point.
Old Jul 2, 2021 | 04:31 PM
Barry's70LT1's Avatar
Barry's70LT1
Binnie did a great conversion documentation. http://corvettec3.ca/tko.htm
Old Jul 2, 2021 | 11:59 PM
cagotzmann's Avatar
cagotzmann
Here is my T56 magnum 6 speed conversion notes. Changes since first install is to a dual clutch for a lighter clutch pedal.
T56 Magnum Install 78 Corvette. - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Jul 4, 2021 | 11:13 PM
simon60's Avatar
simon60
Thanks everyone.
There's more to it than I thought.
Old Jul 5, 2021 | 12:47 PM
iokepakai's Avatar
iokepakai
Here's my Richmond 6 speed swap..https://www.corvetteforum.com/forums...am-change.html
Best mod on the ol vette ..Most expensive too! Well worth the time & $$ ..The Richmond is same length as the TH350 used the same driveshaft just a new yoke on the trans output..
Pedal assembly was the worst part of the job ..Z Bar bracket on the frame was flexing ,got a stronger one from a forum member.Didn't weld the bracket I drilled and tapped the frame .
Also used a Gforce Trans crossmember .If you have the funds go for a complete kit save you the hassles chasing down parts...Good luck with the project!
Old Jul 5, 2021 | 04:39 PM
Dusky's Avatar
Dusky
Depends what you want to do.
you can go the easy and expensive way ( tremec) they're virtually a direct fit. Same driveshaft, crossmember,... so just cut a hole for the shifter, change the center console plate , add a clutch, bolt or weld the Z bar bracket and wire up the reverse.
Or, do like me and buy a T5 out of a late 80's camaro and get a shorter driveshaft and modify your crosmember. All depends on your skill level and how much your wife let's you spend on the car 😉
Old Jul 5, 2021 | 11:05 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I recommend the TKX CR box. 2.87 1st .68 OD
With a 3.36 you'll have 10:1 in first gear, very peppy.
OD will give you 2050 rpm at 70. Very relaxed Hwy cruising.
But probably means you will be in 4th til 60 or more til you got to 5th.
That's not as big a deal as some say, it's what my street car does everyday.
My buddy geared his way different with 4.11s and same trans. He can use 5th gear from 50 rpm up. But has so much 1st it just lights em up very easy.
I just got my TKX last wednesday!
It was 8 week delivery from Silversport.
And the CR/.68 is the only version Tremec is making right now anyway, the other 2 gearsets have an unknown delivery date.
Here is a spreadsheet you can play with ratios if you like:
File Type: xlsx
Old Jul 9, 2021 | 10:54 PM
simon60's Avatar
simon60
Thanks for the spreadsheet
Old Jul 9, 2021 | 11:22 PM
76strokervette's Avatar
76strokervette
Here is a nice write up on auto to 6 speed. https://www.corvetteforum.com/forums...on-thread.html
To Converting from auto to 5spd question
