Muncie Interlock Cable Length
Old Jul 13, 2021 | 04:03 PM
Cavu2u's Avatar
Cavu2u
Default Muncie Interlock Cable Length
I'm confused of what LENGTH the Steering Interlock Cable should be on this '73 SBC.
It's a pre-70s M20 (no TCS switch) that I have to replace the TH400. Just wanna be sure I buy the right length cable, as there are various lengths listed for the same year 4-speed car. If anyone has one loose to measure (or sell ) that's a known fit, please advise me.
It's very much appreciated. Thank you.
steve
Old Jul 13, 2021 | 05:10 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Old Jul 13, 2021 | 06:33 PM
Cavu2u's Avatar
Cavu2u
Well, that's about a complete of an answer I ever received! Thanks so very much PJO.
Sure helps getting the project rolling.
Steve
Old Jul 14, 2021 | 01:29 AM
theandies's Avatar
theandies
Steve
Set your shifter up to short throw buy adjusting the rods to the holes in the trans levers closer to the pivot point.
Put indexing tool in shifter
Adjust using AIM instructions This picture shows the interlock or backdrive cable as they call it.
Adjustment to the holes mentioned.
Scan of my original owners manual talking about short throw .
I have it setup this way in my '71 and it's a lot better than stock.
Old Jul 17, 2021 | 11:01 PM
GUSTO14's Avatar
GUSTO14
Zip and Wilcox both only show one Steering Column Interlock Cable for the 69-75(76) w/4-spd equipped cars. I believe they call it a 31" cable.
OE GM PART #: 3949074
ZIP - https://www.zip-corvette.com/69-75-w...MaAuUuEALw_wcB
Wilcox - https://willcoxcorvette.com/corvette...eed-69-76-repl
Good luck... GUSTO
Old Jul 18, 2021 | 01:35 AM
0311 jarhead's Avatar
0311 jarhead
What manuals have you gotten that have these diagrams??? None of mine do
Old Jul 18, 2021 | 10:11 AM
theandies's Avatar
theandies
The Assembly Instructions Manual. You can find it from most vendors.
The AIM is the instructions the factory used to do final assembly. My go-to book.
Old Jul 18, 2021 | 12:28 PM
0311 jarhead
Thanks, just ordered one from NCRS
Old Jul 19, 2021 | 09:52 AM
PJO's Avatar
PJO
Old Jul 19, 2021 | 01:01 PM
Cavu2u's Avatar
Cavu2u
Default Speedometer Cable Length Question
Originally Posted by PJO
Thank you very much for including this Speedometer length information for my use. Very much appreciated.
Steve
Old Jul 19, 2021 | 01:14 PM
71 Green 454's Avatar
71 Green 454
Good luck... GUSTO
The Willcox link you posted is the one I purchased, now it's discontinued. It didn't last very long, glad they stopped selling it.
Be sure to purchase the correct type with the wrapped steel case, not the black plastic coated.
https://www.zip-corvette.com/69-75-w...ock-cable.html
To Muncie Interlock Cable Length
