sparkplug gap question
Old Dec 17, 2002 | 11:56 PM
telk's Avatar
telk
Default sparkplug gap question
what gap should I use on a 69 smallblock with stock distributor and Petronix module? Does a wider gap mean more spark? Think I have it at 035 now and plugs seem a little gas fouled. Thanks Telk
Old Dec 18, 2002 | 12:47 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: sparkplug gap question (telk)
My guess, .40 or .45 probably wouldn't hurt.
.45 is pretty common on the Big blocks.
What part of the Bayou State are you from, just outside of Lafayette here.
Old Dec 18, 2002 | 08:31 AM
Corey_68's Avatar
Corey_68
Default Re: sparkplug gap question (71,454,4spd)
If you want a little more fire you can open them up to .50. The wider the gap the more spark, but less spark plug life. The narrow gap is the opposite. This is all within reason of course.
:cheers:
Old Dec 18, 2002 | 08:40 AM
pws69's Avatar
pws69
.35 is correct. If you are fouling, I would say it's most likely a carb issue (too rich). Wider gaps are used with HEI, but are more likely to be problematic without HEI.
Old Dec 18, 2002 | 09:45 AM
Surfer69's Avatar
Surfer69
With petronix and hotter coil it says use .045. That's what mine are at.
Old Dec 18, 2002 | 03:06 PM
pws69's Avatar
pws69
Default Re: sparkplug gap question (Surfer69)
You are correct - but he said Pertronix MODULE - not coil. With the stock coil, .35 is the ticket.
Old Dec 18, 2002 | 07:09 PM
telk's Avatar
telk
I might try 40 or 45. Baton Rouge. Thanks
To sparkplug gap question
