Brakes
Old Jul 19, 2021 | 09:05 PM
coy_staen's Avatar
coy_staen
4th Gear
Default Brakes
A couple nights ago I was driving home when I noticed my passenger rear tire screech and there was sparks coming out behind me, pulled over and my rotor was glowing red. I was thinking the caliper got stuck so I replaced it. But I’m kind of sketched out to drive it because idk if that was the issue or if there are going to be more issues. Any thoughts? Also might think it could be wheel bearing issues
Old Jul 19, 2021 | 09:35 PM
Peterbuilt's Avatar
Peterbuilt
Did you chance out the rubber brake lines, as they sometimes clog on the inside and not release the pressure.
Old Jul 19, 2021 | 10:40 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
You should put the rear frame on jack stands/block the front wheels from rolling/put the car in neutral and rotated the rear wheel to see if there is still schreeching-rubbing noises before driving the car.
Also...if the parking brake assembly (inside the drum of the rotor) comes apart it will act the same way...
BUT you should follow Peterbuilt's advice and eliminate all other possible points of failure FIRST.
Old Jul 19, 2021 | 11:15 PM
coy_staen's Avatar
coy_staen
4th Gear
No I did not even think about that. Should I replace them or just unclog them if they’re clogged
Old Jul 19, 2021 | 11:32 PM
Peterbuilt's Avatar
Peterbuilt
The best practice is to replace all 4 of them.
Old Jul 20, 2021 | 08:53 AM
7T1vette's Avatar
7T1vette
No way to 'unclog' deteriorated rubber hoses. Replace them if they are old; and replace ALL of them to be safe.
Old Jul 20, 2021 | 01:22 PM
kansas123's Avatar
kansas123
Did you take any pictures of your caliper and rotor, was the rotor scratched or marred up? Doesn't sound like you tried to take to rotor off and if you could tell it was locked/bound up. Just curious what that looked like. Good luck with your brakes.
Old Jul 20, 2021 | 01:49 PM
Peterbuilt's Avatar
Peterbuilt
I agree, remove the caliper and rotor and inspect the parking brake parts.
To Brakes
