Read my spark plug
Old Jul 20, 2021 | 09:15 PM
7t5's Avatar
7t5
St. Jude Donor '14
Default Read my spark plug
I only pulled #1 and took a pic. It has roughly 1,000 miles on it.
Whad'ya think?
Old Jul 21, 2021 | 12:57 AM
7T1vette's Avatar
7T1vette
Plug looks fine. But the threads would indicate that you probably have a valve cover gasket leaking oil down on the plug...
Old Jul 21, 2021 | 01:41 AM
7t5's Avatar
7t5
St. Jude Donor '14
Yes! But not anymore. I got rid of the parts store chrome valve covers and installed original style orange stamped steel covers with cork gaskets. Much better now.
Old Jul 21, 2021 | 11:45 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
That tan line on the strap makes the turn nicley and appears to be near the base which is good. How does it look down inside around the electrode insulation
Old Jul 21, 2021 | 01:16 PM
REELAV8R's Avatar
REELAV8R
Too cold, need a hotter plug imo
Old Jul 21, 2021 | 01:40 PM
MelWff's Avatar
MelWff
Your profile says you have a 75 L48.
If that is correct and unmodified, the correct plug is a 45 heat range not the 44 in the picture.
Old Jul 21, 2021 | 01:50 PM
L-46man's Avatar
L-46man
Default x-2
plug looks normal.
Clean spark plug hole, anti-seize the treads, check for leaks.
The oil burning telltale would've been in the 'socket' area of the plug....there's no carbon in there....this would not have been burnt off by the plug firing nor the explosions, it's in the cooler condensing valley of the electrode.
All ist Gut!
Unkahal
Old Jul 21, 2021 | 03:35 PM
sunflower 1972's Avatar
sunflower 1972
Old Jul 21, 2021 | 04:27 PM
7t5's Avatar
7t5
St. Jude Donor '14
Originally Posted by L-46man
plug looks normal.
All ist Gut!
Unkahal
Awesome. Thanks.
How to clean the threads w/o dropping crud into the cylinder? Use a tap?
Old Jul 21, 2021 | 04:28 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Came across this from Steve Morris Engines. Interesting and good, in-depth explanation.
Old Jul 21, 2021 | 04:29 PM
7t5's Avatar
7t5
St. Jude Donor '14
Okay, thanks.
You are the third person to indicate using a hotter plug. One friend of mine and someone in a pm. were the others.
Old Jul 21, 2021 | 04:31 PM
7t5's Avatar
7t5
St. Jude Donor '14
Hmmm, I'll try to get out there for another pic.
Old Jul 21, 2021 | 04:58 PM
L-46man's Avatar
L-46man
Originally Posted by 7t5
Awesome. Thanks.
If it was me....
Screw in clean plug about 3 turns.
Blow out spark plug hole with high pressure compressed air.
Remove plug
Clean with lacquer thinner on clean rag buy twisting the rag and dragging junk out of the hole.
I use nickel anti-sneeze in the plug holes.
BTW, one big mistake I have seen is OVER 'sneezing' the plug threads....reminding you that some of the threads protrude into the combustion chamber....anti- sneeze is conductive...I've seen guys 'kill' the sparkplug by over sneezing.
best of luck....go slow.
Unkahal
To Read my spark plug
