75 Corvette Fuel lines
Old Jul 27, 2021 | 05:33 PM
rodney25's Avatar
rodney25
Default 75 Corvette Fuel lines
Hi All,
I have a 1975 Corvette with BluePrint 350. Ordered a new fuel pump with higher PSI & GPH than stock. My original fuel pump is a 3 port but the new fuel pump is a 2 port.
My question is can I convert the fuel line to 2 port? Or must it stay as 3 port. I know one line is fuel from the tank and the other line goes to the carburetor, but what is the 3rd line for and can you get ride of it?
Old Jul 27, 2021 | 06:39 PM
69L88's Avatar
69L88
The third “port” is for a return line back to the tank. You need to keep that return line because it is key to keeping your under hood fuel cool, avoiding vapor lock.
Old Jul 27, 2021 | 07:04 PM
rodney25's Avatar
rodney25
Can I use the Holley 2 port fuel pump and use a none orafist vapor filter separators (ACDelco 25055048 - Professional Fuel Filter) for the 3rd line to support vapor lock?
Found this link on YouTube
Old Jul 29, 2021 | 06:24 AM
7T1vette's Avatar
7T1vette
Doubtful, with today's ethanol-laced fuel...
Old Jul 29, 2021 | 06:57 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Bloody hell Mate. just do it right. why try cutting corners. Just do it right the first time.
Old Jul 29, 2021 | 12:44 PM
kodpkd's Avatar
kodpkd
I installed the AC fuel filter with return line and solved my hot start issue.
Old Jul 29, 2021 | 02:34 PM
OldCarBum's Avatar
OldCarBum
You should put a fuel pressure regulator and gauge in the system as well.
If your fuel pump doesn't have the return line port, just make sure the regulator does.
Old Jul 29, 2021 | 02:55 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Return the pump and buy the stock replacement......you do not have enough power to worry about it. The highest rating of the Blueprint 350's is 385 and a stock pump will run that just fine and be happy with the stock return line setup.
Jebby
To 75 Corvette Fuel lines
