Wildwood Take Note!
Old Aug 14, 2021 | 02:02 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Originally Posted by 3X2
Not a design flaw, but an user installation manual flaw. Wilwood needs to add to the installation instructions that the rear calipers need to be held vertical to bleed properly before mounting. I'm sure they could also source the correct length bolts so as not to have the supplied bolts lock the rotor without shimming. Redesigning the caliper to get a proper bleed in the installed position is also an option. If GM did it, why not Wilwood?
Agreed 100%. Looking at post 9 & 10 above it is very obvious to see that the Dodge caliper is mounted at approximately twice as much of an angle as the rear C3 caliper. Obviously both cars are using original caliper mounting brackets and angles.
Wilwood should be able to easily figure out at what angle this problem becomes critical, even with the "undercuts" mentioned, and should supplement it's instructions. We figured it out by trial and error!
Maybe they should send the forum a check for "R&D work" LOL!
Old Aug 17, 2021 | 03:52 PM
hdeyong's Avatar
hdeyong
Maybe Willwood should call their next calipers Windows 11. Let the customer figure it out and fix it.
Old Aug 19, 2021 | 03:09 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
It's not just Wilwood.
It is almost every aftermarket part and repo part manufacturer. I am going thru the same issue with McLeod, Howe and Lokar.
It's the old 50% rule all over again. A lot of the parts only halfway fit. Here is a phone quote from a manufacturer from yesterday: "Oh yeah, we know, sometimes you have to move the fuse box over a little bit and grind the hole in the firewall a little bigger" Are you kidding me? Why can't they just design it properly the first time?
The days of an aftermarket part fitting as good as a GM part are long gone.
If you want to "mod" the car you just have to be willing to deal with this stuff.
Old Aug 19, 2021 | 06:02 PM
Ken Chevy's Avatar
Ken Chevy
Wil wil wilwood days
Wil wil wilwood days.
now I got that damn song stuck in my head.
Does Wildwood, NJ still do those car show parades? Haven't been there in a long, long time.
Always wanted to do one of those Doo Wop architecture tours if those mid-century "Googie" style hotels and restaurants still exist today. They had grandiose mid-century names like "The Riviera" or "Bel Air" or "The Royal Hawaiian"... even though it was a New Jersey beach.
Old Aug 19, 2021 | 07:06 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Yep! Thursday Sept 23rd!
Old Aug 20, 2021 | 12:55 PM
TorchZ51's Avatar
TorchZ51
Originally Posted by Factoid
I also gravity bled mine to a perfect pedal, but I did need to hang the rear vertically.
Ready to go.
Inside first, then outside.
Thought they looked good, but no.
Had to hang them to get that last little bit of air out.
How long did it take to gravity bleed using this method?
Old Oct 5, 2024 | 01:56 PM
stanwright's Avatar
stanwright
1st Gear
thanks for the heads up.....saw another post on the red c3 tail end conversion. what year c3 was that?
Old Oct 6, 2024 | 11:18 AM
vettebuyer6369's Avatar
vettebuyer6369
Post does not appear related to the last post from 7 years ago.
