Reverse switch install
Old Aug 7, 2021 | 05:10 PM
Cmurray79's Avatar
Cmurray79
Default Reverse switch install
1979 super T 10 trans. I pulled this off when i replaced the clutch and i dont remember how it goes on. What does the rod connect to? Which hole does it go in on the switch? Pics would help a lot.
Old Aug 7, 2021 | 05:20 PM
interpon's Avatar
interpon
Post 8 and 56
ill search aim and add
https://www.corvetteforum.com/forums...r-etc-diy.html
I also took this picture in my archives for some reason I must’ve thought it important
Old Aug 7, 2021 | 05:23 PM
Cmurray79's Avatar
Cmurray79
Originally Posted by interpon
Post 8 and 56
thats exactly what I was looking for, thanks.
Old Aug 8, 2021 | 08:45 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Old Aug 8, 2021 | 08:48 AM
Rescue Rogers
these are from a muncie but it should be close. The bracket is adjustable so when you mount it, have the car in reverse with the key in the on position and you should see the lights come on as you get the switch to the on position. Then after you mount it take it out of reverse and if it doesnt go off you just twist the whole switch itsef until it shuts off then tight it and test again.THe shield should point down to protect it from road splash and bouncing debris
To Reverse switch install
