Front turn signal bulb
Old Aug 9, 2021 | 05:24 PM
xMrFacex's Avatar
xMrFacex
Default Front turn signal bulb
Hello friends working an 81'. I've been looking for a front turn signal bulb. All local parts stores are saying this Slyvania bulb is the right fit, however the locking bumps are staggered compared to the old bulbs which prevent it from turning in place and securing it. Also the end connection has bumps 2 compared to it being 1 on the original , and the 2 ends run perpendicular to the locking bumps. Anyone else have this issue? We're can I get the correct bulb for this, I can't find it anywhere beyond places continuing to recommend this same bulb.
Below is the original bulb
Old Aug 9, 2021 | 06:32 PM
Barry's70LT1's Avatar
Barry's70LT1
In mine, all signal/park bulbs are 1157, two filaments. The bulb you have in your hand (pins opposite) is a 1156, used for back-up light.
Seems odd that in '81 the bulbs would have changed.
Does an '81 not have park lights, only signal.?
Old Aug 9, 2021 | 06:45 PM
xMrFacex's Avatar
xMrFacex
How is the bulb I have an 1156, the packing indicates 1157.
Old Aug 9, 2021 | 09:32 PM
Barry's70LT1
You are holding two different bulbs.
The 1157 has the pins staggered across from each other.
The 1156 has the pins directly across from each other, you are holding that in the second photo. You state the 1156 is the original. I have never seen that before in a signal, only in a back up (reverse) bulb.
Therefore the question, does an '81 have park lights in the front ? If so where are they.? Typical configuration is a 1157 bulbs front and rear. Dual filament, one for park lights, one for signal.
Just trying to understand why a 1156 in your front signal ?????
Old Aug 9, 2021 | 09:39 PM
Bikespace's Avatar
Bikespace
Perhaps this helps.
Old Aug 9, 2021 | 09:55 PM
xMrFacex's Avatar
xMrFacex
I was confused on which you were talking about. But yeah idk why its like that then, I've never changed them and the housing looks like it's never been changed before, actually had to wrestle one of the metal part off the bulb because the glass came right off and was filled with yellow gunk that was keeping it in there. So I imagine it's been the same bulbs since 81. I'll check out the other bulb number for sure though.
Old Aug 11, 2021 | 10:16 AM
7T1vette's Avatar
7T1vette
I don't know which is the correct bulb. The 1157 has two filament, of which one is a brighter brake light filament; the other is a weaker tail light filament. The front lamp is just running light or turn signal. That function could be done with just one filament...depending on how GM designed it. Check the internet or owner's manual for determining the correct bulb for that application.
Old Aug 11, 2021 | 12:18 PM
xMrFacex's Avatar
xMrFacex
I got the correct bulb yesterday it was the 1156.
edit: also there are two bulbs for the front the small bulb I belive a 168 is the actual turn signal bulb because it sits behind an orange plate and the larger one looks like it's a running light sits behind a white plate.
Old Aug 11, 2021 | 01:01 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
What does your owner's manual say?
Old Aug 11, 2021 | 01:06 PM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
If you aren’t trying to stay stock, get led. Will last longer and very bright. Easy to get on Amazon. I’ve don’t interior lights this way but not turn signals but I don’t think it would make a difference as long as you get the right size.
Old Aug 11, 2021 | 01:07 PM
xMrFacex's Avatar
xMrFacex
It told me to light a match and put it in the plastic housing.
Old Aug 11, 2021 | 01:30 PM
F4Gary's Avatar
F4Gary
Then go get a match.
To Front turn signal bulb
