1982 Shock Replacement
Old Aug 15, 2021 | 08:32 AM
JMalone88's Avatar
JMalone88
Default 1982 Shock Replacement
Hello,
I am looking to replace the shocks on my stock corvette. I do have a 340lb fiberglass rear leaf spring. I am looking for a confrontable ride apposed to something sporty as I don't have a lot of fun curvy roads in Iowa. I have seen comments about the Bilstein HD shock and I am not apposed to it but was looking more at AC Delco or Monroe that are a better price range. I don't want to waste my money on over kill shocks or cheap shocks either so looking for some input. Thanks
Old Aug 15, 2021 | 08:58 AM
Fly skids up!'s Avatar
Fly skids up!
Get the Bilsteins. Buy once, cry once. You won't be happy with those cheap shocks with the 340 spring. Ask me how I know.
Old Aug 15, 2021 | 09:12 AM
interpon's Avatar
interpon
I have no experience with plastic spring but do with bilsteins and ac delco.
mx made ac delco gas are ok daily driver stock but will fall apart. Don’t waste money.
https://www.corvetteforum.com/forums...nt-advice.html
bilsteins front awesome usa made, rear later steel 10 and 6 leaf good..but rears and recent order now made in mexico..i would seriously take advice for rears and your plastic spring and even entertain usa made alternatives.
I also got good advice here but I’m steel rear
https://www.corvetteforum.com/forums...ce-please.html
Old Aug 15, 2021 | 09:25 AM
JMalone88's Avatar
JMalone88
So go with the Bilstein HD set?
FLY Skids Up - I have the same color corvette.
Old Aug 15, 2021 | 09:58 AM
interpon's Avatar
interpon
seems safe bet..
my rear
https://www.corvetteforum.com/forums...s-install.html
pay attention post 15 for front install as directions wrong
Old Aug 15, 2021 | 10:07 AM
Fly skids up!
Even a better reason to go with the Bilsteins!
Old Aug 15, 2021 | 10:25 AM
Cmurray79's Avatar
Cmurray79
I have QA1 single adjustable shocks. Adjusts with a turn of a ****. Dial them in as you drive. I run a 360 lb spring, with the shocks at 10/16 clicks (more clicks=stiffer ride). I’ll dial them back to 8/16 for long drives.
Old Aug 15, 2021 | 10:32 AM
interpon's Avatar
interpon
Originally Posted by Cmurray79
I have a 360 spring, with QA1 single adjustable shocks. Adjusts with a turn of a ****. Dial them in as you drive. I run a 360 lb spring, with the shocks at 10/16 clicks (more clicks=stiffer ride). I’ll dial them back to 8/16 for long drives.
nice..usa made too…i would have tried them if i knew bilstein went mx
https://www.qa1.net/automotive/suspe...-shocks-struts
Old Aug 15, 2021 | 11:31 AM
Mrvettenick's Avatar
Mrvettenick
Just curious, as a starting point, what shocks do you have now?
Old Aug 15, 2021 | 06:07 PM
JMalone88's Avatar
JMalone88
I bought the car as a project so I have been fixing it up. I am not sure about the front shock as the wording is off of them but the back says Monroe Sensa Trac.
Old Aug 15, 2021 | 06:36 PM
Mrvettenick
If you[ do normal driving, KYB's work.
Old Sep 12, 2021 | 09:04 PM
JMalone88's Avatar
JMalone88
Installed the Bilsteins HD shocks today and they ride really nice. Wish they would have included instructions in the box for the fronts shocks to make sure I put the washers on correctly. They made sure to include stickers so they must of thought those were more important.
The Monroe shocks I took off were completely junk. Pushed them down and there was no return in 3 of the 4.
Old Sep 12, 2021 | 09:33 PM
interpon's Avatar
interpon
thats why i mentioned the directions in post 5.. for fronts
Old Sep 12, 2021 | 10:05 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I think 78-82 are all the same. I just looked at my 82 ASM and it shows the same thing for the rear shock assembly. Although, mine actually has all the numbers in the boxes. I've had Bilstiens on mine for a long time and like them.
Old Sep 12, 2021 | 10:14 PM
JMalone88's Avatar
JMalone88
Yes, those posts were very helpful.
The one thing I am still not 100% sure of is the top nuts on the front shocks are tight enough. I ran them down with 9 thread showing which seemed to be a reasonable amount of rubber squish. Definitely wasn't hard to run the nut down with a ratchet wrench and the allen head wrench so it is hard to determine if tight enough. Is there somewhere posted it tells you how far to run the nuts down?
Old Sep 12, 2021 | 11:32 PM
7T1vette's Avatar
7T1vette
Monroe Gas-Matics will work for you. But, they won't last anywhere near as long a the Bilsteins. But, they will give you a decent ride and be a lot easier on your wallet. If you wanted the Bilsteins, I would tell you B6's in front and B8's in the back.
Old Sep 13, 2021 | 07:58 AM
interpon's Avatar
interpon
great question , i also struggled with that.. so i leave them at squish until rubber is size of washer..( i think if i remember it was 14#?)
now my sway bar links had a torque spec.. and no way as it really squished them (loaded or unloaded) so i left at normal squish to washer. Then i was doing a round about at speed and thought the entire front end came apart. It was the sway bar link lol..so now i am between torque and over squish..
Old Sep 13, 2021 | 08:55 AM
Fly skids up!
I generally go about five or six turns more after after all the slack is taken up.
Old Sep 15, 2021 | 10:15 PM
7T1vette's Avatar
7T1vette
The shock is the hydraulic damper for that suspension member...you don't NEED the rubber cushion, other than to limit shock loading of that rod/nut. You need to make the rubber bulge some. You don't want a 'loose' connection there.
To 1982 Shock Replacement
