Fuse puller tool
Old Aug 25, 2021 | 02:58 PM
Johnf692's Avatar
Johnf692
Default Fuse puller tool
Can anyone please tell me which glass fuse puller tool would be best to use on a 69 vett? I have a drain I want to check out and I tried using a small flat head screwdriver to start pulling fuses with not much luck. I remember reading some members suggesting this tool, but there are so many on Amazon, I’m not sure which one is best for my application. A pic or specific name would be helpful. Thanks!
Old Aug 25, 2021 | 03:52 PM
MelWff's Avatar
MelWff
Is this the thread you are looking for?
https://www.corvetteforum.com/forums...ullers-c3.html
Old Aug 25, 2021 | 08:54 PM
Johnf692's Avatar
Johnf692
Thanks. The thread was helpful. I wasn’t sure if just any puller can be used on a 69, or if I needed a certain type. I’ll just pick one up and hope it works!
Old Aug 25, 2021 | 11:38 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Just hit your local auto parts store –– you'll find the hook type puller for just a few bucks. Depending on how corroded the metal clips are in the fuse block, you can count on breaking a few fuses in half. Try to clip the puller over the fuse body close to one end and pull that side out. Then use your fingers to pull the other end of the fuse free... at least that's what generally works for me.
Old Aug 26, 2021 | 08:24 AM
7T1vette's Avatar
7T1vette
I have a set of plastic pry tools. I use the end of one of those which will fit under the fuse. It needs to be about the same width as the glass portion of the fuse, to prevent breaking the glass.
Old Aug 26, 2021 | 11:37 AM
Johnf692's Avatar
Johnf692
Thanks for all the feedback. Going out today to pick up a puller. Hopefully won’t break too many fuses.
Old Aug 26, 2021 | 02:35 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
i always used a pocket screwdriver on the metal part of the fuse approach it from the end
Old Aug 26, 2021 | 10:11 PM
7T1vette's Avatar
7T1vette
....after the battery was disconnected....of course.....
Old Aug 27, 2021 | 04:48 AM
ralphspears
Banned Scam/Spammer
With battery connected
To Fuse puller tool
