1973 Corvette
Old Aug 26, 2021 | 07:16 PM
ConnorBeaton1973's Avatar
ConnorBeaton1973
Default 1973 Corvette
Hello everyone,
I own a 1973 Corvette with a 350. Last week I took the car for a ride and after about 3 hours of it sitting, I went to start it up and it died. After a few more times, it finally ran but something didn't seem right because the RPMs were running low (500-550). I talked to my dad and he said it was a vacuum problem. We FaceTimed tonight and we figured it was not a vacuum problem but, a carburetor problem. The car has a Holly 750. After the car was running for 5 minutes and it was warmed up I put the car in drive and the RPMs dropped again to 500-550. The car also idles at 650-700. To me, the car sounds like it is barely hanging on when in drive. Has anyone has this issue before or knows how to change it? Thank you and drive safe!
Old Aug 26, 2021 | 08:44 PM
kansas123's Avatar
kansas123
So I would start by trying to set the idle at about 800 and then seeing what the time is set up, might just need some tweaking there.
Old Aug 27, 2021 | 07:16 AM
Mr D.'s Avatar
Mr D.
Originally Posted by ConnorBeaton1973
Hello everyone,
Using your high numbers
Curb idle - 700
Drive idle - 550
A drop of 150 RPM when going from Park to Drive.
This is normal, adjust your curb idle up a little as kansas123 stated and it should be fine.
To 1973 Corvette
