I use the box that covers the distributor and the sides because I like the look. They don't interfere with my headers at all. I can't imagine the V brackets would interfere either.
If you just want the car to appear as it did when new, go for it. That wire shielding was just a way to drain-off ignition EMF to chassis electrical ground. There is no 'magic' in them; they just go around the spark plug wires and ground out to the block. If the originals are nice enough to put over new wires, go for it.....
I have 8mm wires under "v" shields, distributor shield, and the two down shields all in place, with headers. Same wires, (Accel), installed for 25 years. Nothing burned yet !
Thanks. That what I'm gonna due. I like the look and I like the safety
