Cam suggestion
Old Sep 9, 2021 | 11:02 PM
  #81
Pale Roader's Avatar
Pale Roader
Originally Posted by Richard Daugird
Depends on where in Texas, it's 790 miles from north to south, 660miles across. Even in Dahlhart, coldest city in Texas, it's 77 degrees today. Only 9 degrees cooler than here on the island. I'm keeping my A/C!
I was in Killeen.
Old Sep 11, 2021 | 07:18 AM
  #82
stingr69's Avatar
stingr69
Those older GM cams make good power with inexpensive valve trains and fairly good idles but you need around 10.5 C/R to get them to run right. Without that, they are dogs.
I run a L-46 350/350 cam with 10.5 C/R with flat tops, iron aftermarket heads with modern kidney bean chambers and a tight quench. You can barely notice any idle shake. Easy to live with, pump gas, closed hood type vehicle. Pulls well all the way up to 6000 RPM.
