Carb #7041212 DL I put a kit in it but I have no real adjustment withe air/fuel screws. I turn both of them all the way in and it has no real effect, same thing if I turn them out. the motor idles pretty rough too. I put a vacuum guage on it and watched it as I adjusted the mixture screws, I saw no real change there either. Is this a bad throttle body?
Originally Posted by dprinter1
I went ahead and ordered a re-manufactured carb, I'm tired of fooling with it. .
That's a really bad idea, and a complete waste of time and money. The commercially rebuilt carbs are complete junk, and are best used to practice your hook shots into the garbage can in your garage. Neither Cliff nor I will touch those things. E-mail me for a copy of my paper "Commercially Rebuilt Q-Jet Problems" if you'd like to see a 3-page list of just a few of the things that will be wrong with that carb. Fix your original carb properly (soaking it in a "dip can" is not going to clean out the idle passages) and scrap that "remanufactured" thing.
Cliff and I have both been accused of being, "harsh," "intolerant," and "ridiculous" regarding our opinions and comments about the commercially "remanufactured" carbs. Unfortunately, we speak the truth, and the truth is brutal when it comes to junk carbs.
Lars V8FastCars@msn.com
It's a plugged idle feed circuit in the carb, improper assembly, incorrect gaskets, or an incorrect setup. You're idling on the main discharge circuit.
Lars
Thanks for that Lars. I took it off and ran some wires, cleaner and air through it and that helped it a lot, at least it will idle now.
Check the gasket used between the main casting and baseplate. Unless you use an application specific kit they typically supply several choices and there was a change made in those gaskets and using the wrong one blocks idle bypass air. The idle tubes really need to be pulled to effectively clean them. Running wire thru them may open them up but will not remove the 50 years of "varnish" built up in the tips from countless drying up cycles. I sell the most complete and correct Quadrajet rebuild kits in this industry and only supply the correct gaskets and parts used in the carb by part number.......Cliff
Thank you for your reply Cliff, I'll keep you in mind. The parts are all correct so I'm going to dismantle it "again" and soak it in the dip can for a day or two, then go through the whole cleaning process again. I went ahead and ordered a re-manufactured carb, I'm tired of fooling with it. I'll box up the original after I run it through the cleaning process and save it for my granddaughter.
Anything commercially "remanufactured" is going to be a pile of bovine excrement so good luck going in that direction. I will not touch them here and when they incidentally show up I very carefully close the box and send them back to the owner.
Manual cleaning is required for idle tubes, nothing else will remove the "varnish" built up in them from drying up cycles over nearly half a Century.......
I do love me some truth speakers, my AA sponsor is one of those types, he saved my life and I didn't like one bit of it I have since become just like him
So what do you recommend I use to clean out the idle passages? And where exactly are they, pics? I know very little about carburetors
Several methods can be used to clean idle tubes. They can be difficult to clean effectively as they are driven into the main casting and the small tip is not accessible.
I prefer to pull them and manual clean with a precision drill bit in a pin vise......
Hey Lars............So I installed the kit that I got from Cliff and it helped some, but it still doesn't want to idle smooth enough to call it good. I plugged all the vacuum ports and it didn't help any. I noticed a crack in the base plate where the power break vacuum port is, maybe that's causing it I'm pretty well over it and I'm wondering if you would take a stab at it? If so let me know what I need to do.
