Driver's Side Mirror
Old Sep 30, 2021 | 10:03 AM
Winger76's Avatar
Winger76
Default Driver's Side Mirror
Hey all, Mirror is lose and over 40mph is lowers down. Someone told me work super glue into it but I'm thinking that may be a permanent fix or when adjusted it would just break lose. Any suggestions without having to replace the mirror? Appreciate it!!!
Old Sep 30, 2021 | 11:00 AM
kodpkd's Avatar
kodpkd
You can find how to restore the mirror. I did mine and it works fine now. Start by soaking it in gas to remove the glass. Is a good DIY.
Old Sep 30, 2021 | 04:22 PM
sunflower 1972's Avatar
sunflower 1972
My version of the loose mirror fix: https://www.corvetteforum.com/forums...got-lucky.html
Old Sep 30, 2021 | 04:32 PM
wwiiavfan's Avatar
wwiiavfan
https://www.youtube.com/watch?v=NTxlL_NJ4SI
I have done this fix, it works very well.
Old Oct 1, 2021 | 02:54 PM
robertea's Avatar
robertea
Default Quick Fix
I saw all of the methods of removing the glass and fixing the inside of the mirror, but came up with my own fix which takes about 2 minutes which includes getting tools. Get a sharp center punch and a small tack hammer and then tip the mirror to several of its extreme positions and make a mark with the center punch in several of these positions. Do not hit it hard, you only want to make a small mark on the mounting ball. You do not have to take the mirror assembly off of the door.
I did this several years ago and it is still working fine
Old Oct 1, 2021 | 03:40 PM
pmr2000's Avatar
pmr2000
Obviously not a permanent solution or correct solution but the super glue does work - not that it glues it into position it just gives the ball more thickness to tighten it up in the socket. Make sure you do not drip the superglue anywhere......
Old Oct 1, 2021 | 06:55 PM
kodpkd's Avatar
kodpkd
I tried the super glue and the smash the ball joint. Not a great long term fix.
Old Oct 5, 2021 | 12:08 PM
DHer67's Avatar
DHer67
I tried to repair mine per the suggestions on the Forum but it did not work out. First I broke the nub off of the base, then I broke the glass. Not a great showing for someone who makes a living doing home renovations and handyman work. I'm going with the fact that it must have been a cheap replacement part and was doomed from the beginning. I ordered a new one from Southern car parts and it is tight as can be. The part was less than $60 including shipping and tax. Considerably less then the value of my time spent messing with the first one.MIRROR
SKU: X2522
Old Oct 6, 2021 | 02:01 PM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
SKU: X2522
Thank you for the order
To Driver's Side Mirror
