Need Help 12v Coil Wiring
This is an Accel 8140 12V coil.
I have the same unit for many years made by Mallory so something else is going on if that wire is getting hot.
Did the original poster connect the factory wire to the + positive side of the coil?
Did the original poster connect the red wire from the points eliminator to the + positive side of the coil?
Did the original poster connect the green wire from the points eliminator to the - negative side of the coil?
Did the original poster connect the brown wire from the points eliminator to a good ground?
This is a quote from the installation instructions.
"For optimum performance in systems without an ACCEL 275+/300+ or similar
ignition control, use one of ACCEL’s 4 specially matched coils which eliminates the
need for a ballast resistor or a resistance wire. These coils are: 140205, 8140 or
8140C Canister SuperStock coils,140009 HD E-core SuperCoil."
It shows the 8140 coil with the OEM primary resistance wire, not a new wire.
My understanding of the instruction sheet is this. If you are going to use this Accel points eliminator in a 1971 Corvette 350 engine, with a stock coil, then you should utilize the resistor wire built into the stock wiring harness.
If however you choose to use an aftermarket coil such as the Accel Super Stock 8140, then you will need to provide a non-resistor 12v power supply. I think its pretty stupid that they tell you to do this in the instructions, and then provide an illustration that completely contradicts the instructions.
Soooo are you running the stock coil, or one of the aftermarket coils discussed in the instructions?
GENERAL INFORMATION
Ignition Coils:
The ACCEL Points Eliminator Ignition System is designed to work with most stock
ignition coils and aftermarket high performance ignition coils. For optimum
performance in systems without an ACCEL 275+/300+ or similar ignition control, use
one of ACCEL’s 4 specially matched coils eliminates the need for a ballast resistor or
a resistance wire. These coils are: 140205, 8140 or 8140C SuperStock Canister
Coils, 140009 HD E-core SuperCoil.
An GM OEM coil in a points situation applies a full 12v when cranking the engine. In the run position the coil only needs between 6-8v. These high powered coils need a full 12v all the time, and heavier wire to carry the load.
In every thread on this forum there is good advice, unfortunately often wrapped in bad.
Best of luck with the new parts.
