New Posi Case Review
Old Jan 5, 2023 | 10:06 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Yes thank you gary. Your mentoring was indespensible for me, and I feel like I have a stronger posi because of it.
BTW I do have 2 or 3 sets of the solid steel posi clutch discs that I saved if anyone needs some. They are used but measurement shows very little wear. And thicker 17 gear spiders as well. I know few of us are brave enough to dive in and rebuild your own posi, but someone will need these someday.
Old Jan 9, 2023 | 12:01 AM
GTR1999's Avatar
GTR1999
edited
Old Nov 29, 2024 | 11:53 AM
TakeItToMike's Avatar
TakeItToMike
Cruising
Default Posi Case Gears
I opened up my Posi Case/Carrier and am in the process of cleaning and full inspection. What I do notice of the bat is that the cross shaft top & bottom small gears do wobble some when reinstalled on the cross shaft. They obviously ride in the area where the flat spots are on the shaft, but should they have that much play? I understand everything in the case has very close tolerances. Anybody familiar with this or should I go right to Gary?
