New Posi Case Review
Popular Reply
1- Guys still think buying a loaded posi is the best way to replace a broken one or someone talked them into it that is either a seller or clueless.
2- I just inspected another new one today
So, the one today is pretty much like every other new one I checked- sloppy and it's covered up with the huge spring pack. This one the cross shaft didn't have to be tapped out, they should slide out easy. With the spring pack out, I checked the way the spiders were setup. There was 025" endplay in each side gear. To compare this to a correctly tuned posi, and the word correctly is important here, there is no endplay or lash.
The loaded posi will work. Anyone that installed one and says they have no noise I do believe them. What they don't know is that 025" endplay is going to continue to open up on every turn they make. The spring pressure is keeping the clutches quiet by smudging them away. The oil will be black and once the fiber is gone there won't be any posi action.
I recall about 20 years ago, asking my friend Tom about the "new" clutches. They installed a set in a customer's car who drag raced it a few times and pulled the diff for inspection. Anyone who knew Tom would understand his answer "Dude, the fiber came out with the black oil"
So, for those who don't do their due diligence on what they use or someone else uses in their diff, good luck. I still get calls asking, "why does my, (cheap), rebuilt diff have black oil, I have a new posi?" Maybe this will help someone, maybe not.
As cast-iron differential parts Availibility continues to change and shrink, rebuilding one of these differentials to OEM or an upgrade specification is becoming a big-challenge. Your experience captures both Your drive for perfection and the experience brought from countless multiple unit operations. We are all fortunate to have Your skill & knowledge displayed on this Forum. Hopefully someone on this Forum that is smarter than myself is preserving Gary's Posts, photos and all.
Again - THANK YOU Gary for Your time, skill and professionalism.
Yes a lot of the good parts are getting harder to find, add in the con men still out there with their scams, and the fact most don't know how to do custom work anymore so yeah things have changed a fair amount in just the past couple of years.
How about adapting a Ford 9" case to a C2-3?
Many forget or just don't know when they drop in an a new engine with 2-3x the power and torque of the original that everything south of the flywheel needs attention. Some will go by the theory of replacement once broken, others will get the best systems they can but in the end power and abuse will determine what and when things fail, and they will.
Opened another new in the box Eaton and found it like the others. The cross shaft had to be tapped out and now I will have to fit it correctly. So, if you guys are buying new posi cases you better check them and if someone installs one for you then I would be asking a lot of questions before they start.
Now this is better then being too loose for sure but still not right.
I don't really push my car, so I didn't think it would make that much of a difference, but this is after less than 1000 miles, and I have to think the rear suspension is suffering as a result of the end play.
I really should have just waited however long it took for the solid steel clutches to be back in stock, and I've been regretting it since.
The main reason I was rebuilding mine was I swapped ring and pinion from the stock 3.08 to 3.70, as I was going from a TH400 to T56. You always have to find a silver lining in life, so maybe this will push me sooner to go to open it up again, get a new carrier and go to 4.11
I used to get fired up but don't anymore. If some think as above that's their choice to do so and I can't help them. I know I have helped a lot of people with their cars and saved them a lot of money and stress, but there will always be the naysayers that know more than anyone else.
Again, good luck. If you think you got a good deal on a diff, box, TA's, etc I'm happy for you. I am on the other side of the fence and see how many of those builds really are since many end up coming my way to fix.
That was a general statement, not directed to anyone in particular.
To Mongoose, your clutches started smudging away the first corner you took. There are only 14 total in your posi not the 18 that solid steels have and that don't wear down a lot. In addition to the fiber turning the oil black, they are getting thinner and thinner. If you used a new out of the box posi, it was sloppy to begin with. If you used new fiber clutches and tried to tune the posi correctly it's not going to work. Solid steels have been backordered a lot, they are right now in fact. Some places may have them in stock, I usually have them in stock but won't sell them directly if they are backordered as they are today.
PS good luck finding 411's. US Gear is gone, they made the thick 411 for 20 years for Tom's. The only one that makes the thick 411 now are Yukon, who knows it and jacked up the price of everything they sell. Motive only make 355 & 370, Richmond I wouldn't trust and some of the "new" gear suppliers are just reboxing Yukon or Motive.
You want stuff built right....you have to find the right people. Gary is the right person for differentials, steering boxes, and trailing arms....and probably for anything else he would choose to build.
