Transmission problems
Old Oct 16, 2021 | 03:11 PM
croaker's Avatar
croaker
Default Transmission problems
Ok Guys lastest issue went for a cruise and Transmission stated cutting up. Sometimes it feels like it’s not shifting into 3rd and kind of looking for a gear feels like it’s looking for the right gear to be in. Fluid level is good. Could it be the vacuum modulator? Transmission only has abut 4 k if that since complete rebuild but probably 4 years time wise. First chance I get I guess I’ll explore the modulator line. Only issue I’ve ever had with a modulator was a Ford and it wouldn’t shift and was blowing fluid and smoke so no real experience with a 400
Old Oct 16, 2021 | 04:00 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Sounds like the issue I had with the 350 turbo in my Elcamino a couple of years back. Turned out to be the governor gear was trashed. Dropped out of 3rd on the highway. Would still go but not shift onto 3rd. Easy to replace if you can get to it.
Look on you tube for examples and how too's
Old Oct 16, 2021 | 04:36 PM
croaker's Avatar
croaker
Ok. I just ran it around the block now only runs in first. Plus feels like a vacuum miss. Fixin to get it off the ground in a bit
Old Oct 16, 2021 | 06:13 PM
kansas123's Avatar
kansas123
Sounds just like mine after I replaced my trans modulator. Solution was new rubber hose with right size holes for the fitting. Check the hoses to make sure they are sealed well.
Old Oct 16, 2021 | 09:07 PM
croaker's Avatar
croaker
I changed the hose on mod. On bottom took it for a spin seemed ok but once it got heated up same issue and sluggish shift from 2 to 3. I went to change hose at top. Damn.
Old Oct 16, 2021 | 09:29 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
did you find a leak?
test the modulator and see if it holds vacuum
Old Oct 16, 2021 | 09:51 PM
croaker's Avatar
croaker
Nothing definite I guess that nipple could have been leaking. To test on car or off?
Old Oct 16, 2021 | 10:30 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
on or off
it is a vac diaphram so it must hold vac and not leak
Old Oct 17, 2021 | 11:17 AM
croaker's Avatar
croaker
on or off
Holding
Old Oct 17, 2021 | 11:39 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
yes, holding.
shoot.
long shot anyway.
3rd only can be a few things. serious things.
sorry. I would drop pan and look around.
If I was lucky the problem would show.
Old Oct 17, 2021 | 11:45 AM
croaker's Avatar
croaker
yes, holding.
shoot.
long shot anyway.
I still have to change that nipple on the manifold. Fingers crossed if not that on to the governor
Old Oct 17, 2021 | 02:22 PM
croaker's Avatar
croaker
Ok rigged up a nipple with a hose on top took for another cruise. As soon as it got to operating temp. Started cutting up. It just shifts out of nowhere.
Old Oct 17, 2021 | 02:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
wait, it shifts properly until hot?
Old Oct 17, 2021 | 02:41 PM
Eric P's Avatar
Eric P
I’m with this guy , sounds like a Governor problem and it’s external , easy to check and fix …. BUT you need to get your terminality correct as it’s confusing figuring out on what you’re trying to say , like late shifting aka not wanting to shift up to next gear , also how does it shift manually if you take the RPM up ? If you have a clogged/stuck Governor a good full throttle high rpm manual shift from low 1 to 2nd can sometimes clean out the debris causing it to stick
Old Oct 17, 2021 | 04:01 PM
croaker's Avatar
croaker
ok it does fine till it gets operating temp then it doesn’t want to shift. If I manually pull it down to first it shifts. When taking off sometimes it will shift to second most of the time it won’t. If I nail it I’ll get first to second but not drive. Sometimes if I let off and hit it again it’ll shift but then when just cruising along it will shift out of nowhere when it should not.
Old Oct 24, 2021 | 09:23 AM
c69vete's Avatar
c69vete
St. Jude Donor '07
Did you resolve the issue? What did you find as the culprit?
Old Oct 26, 2021 | 11:27 PM
croaker's Avatar
croaker
Not yet I’ll be bringing it to the place that rebuilt it a few years ago hopefully in a couple of days.
Old Nov 12, 2021 | 05:55 AM
croaker's Avatar
croaker
Update it’s at Trans shop. Pan is full of looks like aluminum shavings. 2100 miles since last rebuild
To Transmission problems
