C3 Radiator
Old Oct 23, 2021 | 12:36 PM
MS72C3's Avatar
MS72C3
Cruising
Default C3 Radiator
I have the worst of all worlds - a 72 C3 with a 454 and air conditioning that now has a leak in the radiator. The original had marginal performance at best, so now I am looking to replace the old one with the best available. It appears that an aluminum radiator is the best choice, but there are so many replacement options that all promise easy replacement and great performance. I'm looking for a reality check - someone that has had an experience (good or bad) so I can narrow down the search. I understand that electric fans may be an improvement, but I don't want anything so complex that I have to hire Chip Foose to come to my house to sort it out. I have adequate mechanical skills so will tackle the replacements and upgrades if they are worth the effort. It is also helpful to purchase from someone that offers guidance (Wilcox?) so that when I have pieces scattered all over the garage and reach an impasse, I have someone to call to talk me down from the roof. I appreciate any guidance you all can offer. Thanks
Old Oct 23, 2021 | 12:42 PM
Tampa Jerry's Avatar
Tampa Jerry
Real easy choice. Go with a DeWitts. I installed them in my 66 and 68 L-79 cars and now sit at 180 degrees with the AC on here in Florida. Make sure you have the factory seals throughout. I added a pusher fan on my 66 just in case, but I have never had the cause to turn it on. Great product and great service. Jerry
Old Oct 23, 2021 | 12:48 PM
sunflower 1972's Avatar
sunflower 1972
No need to do any kind of search. This IS the BEST RADIATOR for your BB with A/C.
Old Oct 23, 2021 | 01:14 PM
MS72C3's Avatar
MS72C3
Cruising
Wow - a very quick response AND a consensus. Seems like I have found a supplier - get radiator and all new seals. Clearly, anything I can do to assure the airflow is all directed through the condenser and radiator is worth the effort.
At the risk of putting a $20 saddle on a $10 horse, I'm inclined to go ahead and do the dual electric fans at the same time. I'm not looking to necessarily improve the value in the car, I just love driving the old beast. It's nearly the end of the driving season here in the Midwest, so I have the time available to make sure it is done right for longer trips next year. I appreciate the advice and hopefully will have a success story to share once this is complete. Thanks again!
Old Oct 23, 2021 | 06:50 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
If you decide to go with the electric fans, (I have). Keep in mind that your factory alternator may not be up to the task. A alternator upgrade and the wiring necessary to go with it will add to the cost. You can check out "mad electricals" Web site to learn about charging systems and proper fan wiring.
Old Oct 23, 2021 | 07:21 PM
MelWff's Avatar
MelWff
Before going electric fans consider a Flowkooler pump. Have a member in a club I belong to with a 71 BB w/AC went with a 180 thermostat and a Flowkooler no more problems.
https://flowkoolerwaterpumps.com/
Old Oct 23, 2021 | 07:54 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Dang, I hadn't seen those before. They have pretty reasonable prices.
Old Oct 23, 2021 | 09:26 PM
derekderek's Avatar
derekderek
C5 fan and shroud. And life is way easier to get in and out once that huge shroud is not in the way of everything. The C5 shroud adapts to the aftermarket rad with a couple of pieces of aluminum angle from Lowe’s and you can extend the sides of the shroud the needed couple inches with a black plastic storage bin lid. https://www.ebay.com/itm/15434915300...gAAOSwWENgOoh6
Old Oct 24, 2021 | 02:24 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
I bought a new one at Rockauto. Have yet to install it. Got the wiring kit from Ron Francis. Storage bin lids?
Old Oct 24, 2021 | 04:57 PM
C3Highway's Avatar
C3Highway
To drive the point home, 1979 cars with L-82 and AC had overheating issues from the factory. So much so that Chevy installed auxiliary electric fans and special fan shrouds in such Corvettes. Both are still present and function in my car. Nine years ago I had my shop install a DeWitts radiator in my '79 and it has performed flawlessly ever since. I also agree about making sure you have all your factory seals in place. And make sure you have a good radiator cap.
Old Oct 25, 2021 | 11:27 AM
MS72C3's Avatar
MS72C3
Cruising
Just a quick follow-up to my post. First, thanks to all that responded - this forum is a great resource when embarking on a new project. It is all possible due to your participation and I very much appreciate the advice. I was able to get a radiator from the very helpful folks at Dewitts. They answered on the first ring and I found a inconspicuously damaged (but fully warrantied) direct-fit radiator for $400 (as opposed to the $639 list). I found the needed bits and pieces (hoses, cushions, seals, etc.) at Corvette Central. They, too, answered immediately and had someone who helped me sort out what I needed and transferred me to place the order - the whole call was maybe 5 minutes. Both companies were beacons in a storm-tossed sea of understaffed competitors. I appreciate very much all the help given to get this project going - if only the actual work goes as smoothly...
Old Oct 25, 2021 | 05:40 PM
Hopper12's Avatar
Hopper12
Great choices. We have a '68 L71. Put in a direct fit DeWitts, correct fan clutch, correct seals, rebuilt water pump (stock), new hoses, 180 stat, etc. That thing runs 180 on 95-100 degree days in traffic no sweat. DeWitts fit perfectly and rocks. Best, Paul
Old Oct 25, 2021 | 06:13 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
Another vote for DeWitts. Solved my overheat issues. And make sure all the seals are in place.
Old Oct 25, 2021 | 07:44 PM
interpon's Avatar
interpon
very cool!
while apart, verify fan clutch operation
https://www.corvetteforum.com/forums...re-79-l82.html
Old Oct 28, 2021 | 10:56 AM
Richard Daugird's Avatar
Richard Daugird
Thanks for buying American. As you can see, you get what you pay for! I went with Dewitt's/Spall fans myself.
To C3 Radiator
