First year model "issues"
Old Oct 30, 2021 | 09:39 AM
David Wilson's Avatar
David Wilson
Default First year model "issues"
Here's a helpful list of '68 only items that's been posted before. https://68ragtop.wordpress.com/2012/...t-c3-part-fit/
First year models tend to have problems that need to be corrected, or, GM managers found a way to save a few pennies on each unit by deeming a part too sturdy in original production.
For example, the rear kick ups in the '68 that were added later. Or this, that I plucked from a 2016 thread from 20mercury, "I think the 68 original hood surround was a little light on fiberglass reinforcement on the back side of the 2 front corners and so tended to crack with repeated hood operation. Subsequent 69+ had a larger reinforcement in this area to address this problem."
Now that I'm upgrading and restomodding mine, any suggestions where I can improve on the '68 design with upgrades that were added later in hind sight?
I have already added the kick ups, adding rack and pinion steering, 3 point seat belts, and.... don't judge.... heated seats.
Old Oct 30, 2021 | 10:44 AM
Bikespace's Avatar
Bikespace
The 68's 4 brake lights with separate reverse light configuration is superior. I've matched that in my 80 project. I don't know if that was a bean counter downgrade, but it came back with C4s, and with properly located reverse lights in C6s.
For better cooling, perhaps a chin spoiler, or spoiler extension? Though 81 and 82 came with a plush (weak) high-arch composite spring, I'd strongly suggest a low-arch composite spring (VanSteel, or NOS VB&P are likely your only options), and heim-jointed strut rods.
Do you have a build thread with photos of what you've done?
Old Oct 30, 2021 | 11:23 AM
69L88's Avatar
69L88
Consider putting in 69 door panels. They offer more shoulder room from the original 68 design.
The 68 front spindle diameter (and thus the bearings) are smaller. If you are planning on a lot of driving (especially spirited), you may want to consider swapping those out.
Understand you are “resto-modding” so not sure how much irreversible modification you are contemplating. I raise this point only to say I would recommend you hold onto (properly bag and tag) anything that is 68-only as it would be of value to any future owner.
I understand, anecdotally, that there were/still are a number of electrical “gremlins” associated with the 68. The 68 has an external voltage regulator whereas the 69 and later were integrated into the alternator. Other members on this forum are far more qualified/experienced thanI on electrical matters so I would recommend doing some research on this.
Old Oct 30, 2021 | 11:49 AM
David Wilson
@Bikespace
Thanks for the advice. I haven't started build thread because I'm taking so long to do each step. I retired a year ago and mama has had be busy doing home projects. I'm starting to get back into the car and things will start moving quick.
I have a Tremec Magnum sitting in the garage and am awaiting my supplier to find me the right LS3. With the LS3, I'll do the radiator with fans. I didn't want to be sitting in traffic and overheat.
The rear end is all rebuilt with Van Steel T-arms and QA1 coil overs. That eliminates the leaf spring. I went with the adjustable strut rods with standard joints.
Old Oct 30, 2021 | 11:58 AM
David Wilson
@69L88
Funny you should mention the '69 door panels. I posted a question up only a few days ago about this. I too am interested on having more shoulder room. As I'm already not numbers correct, I figured why not?
As far as any parts I'm not reusing, while I am tagging them with AIM UPC and page numbers, eventually I'm selling those. I just don't want to go through the continued hassle of storing them. Like I said, this has been a long term project. The body has been off for a year while I tackle frame restoration and rebuild. All those parts that came off already have been stored.
I understand about the wiring issues these cars can have. With 53 year old wiring and "Bubbas" working their magic over the years, you never know what you'll find. It is all getting ditched in favor of all new Lectric Limited harnesses. I already have the new dash, rear, and engine harness sitting in a box. My plan is to install the LS, get the body back on and rewire. At that time I'll decide on the sub harnesses.
Old Oct 30, 2021 | 06:22 PM
Bikespace's Avatar
Bikespace
Originally Posted by David Wilson
@Bikespace
Sounds like you are well down the restomod road! Hire a contractor to knock out that honey-do list, and get to work on your car.
I'm looking forward to seeing your project progress.
Old Oct 30, 2021 | 06:33 PM
Tampa Jerry's Avatar
Tampa Jerry
I have had my 68 since 72. One thing I did was upgrade the steering wheel to a smaller later wheel. It is a bit easier if you have power steering. Along the way I also changed out the alt. to a later alt. with an internal voltage regulator. I still love the car after all these decades. Jerry
Old Oct 30, 2021 | 09:55 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
THings I would pass along as good advice is to add a bigger air dam for better cooling, a bigger radiator if you have the small, small block radiator, which would need the big block radiator support. While your at it go to electric fans if you like to drive the beaches, if you live near any. And add a spreader bar which improve the handling if you like the twisties....
Old Oct 30, 2021 | 11:08 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
For what its worth...My '68 is upgraded to a 130amp alternator w/internal regulator
I kept the external regulator (black box) and all wiring connected to it in their original locations to keep the original look of the charging system.
All the wiring from the regulator is "dead-ended" into a wiring bundle.
I also replaced the rusty rear crossmember with heavy duty channel iron for safety
"For Nostalgia purposes only"
Old Oct 30, 2021 | 11:18 PM
7T1vette's Avatar
7T1vette
Not really 'first year model issues, so much as first year "differences". The quality issues were pretty similar from 1968 thru 1979.............
Old Oct 31, 2021 | 10:54 AM
20mercury's Avatar
20mercury
"Consider putting in 69 door panels. They offer more shoulder room from the original 68 design."
Not a bad idea from 69L88 but you need to be aware that the 68 door sheet metal is different from the 69 door sheet metal as the 69 had a pressed in area and weld nut to accommodate the 69+ door handle pull.
I had a friend with a 68 that was installing 69 door panels and could not figure out how the 69 door pulls attached. We finally figured out after looking at my 68 bare door sheet metal that there was a door handle pull design change in the sheet metal. So, I think my friend had to rig up a way to install the 69 door handle pull. Doable but needs some thought.
Cool list of 68 Corvette features! Thanks and 68 is my favorite Corvette of all!
Old Oct 31, 2021 | 12:09 PM
ctmccloskey's Avatar
ctmccloskey
The 1968 Corvette has so many unique items that it should be it's own year designation like the "15th anniversary" or something special. I love the fact that there is nothing on the body and the chrome is kept to a bare minimum. Nowhere on my C3 does it say "Stingray", all I have are the front and rear emblems and the word "
"Corvette" spelled out on the rear.
The 427 BB is very easy to work on as there is room around the engine on all sides but the rear. I can change the spark plugs in 20 minutes from above the engine.
I too pulled the 63 amp original alternator and replaced it with 120 amp Alternator. This is where I have a BIG question. When you have a 1968 Corvette with the external regulator the power coming out of the alternator goes to the battery position on the Horn relay and from there it goers to the ammeter and then to the battery. When I installed the new Alternator I up-sized the charging wire to a 6 gauge marine cable. It goes from the alternator output and the starter solenoid battery connection. The problem is that this does not supply power to the dashboard and fuse panel unless the wire is connected to the battery position of the horn relay to the battery Positive output. Once I connect the horn relay then the system will charge properly but not through the ammeter. It simply supplies power to the fuse panel and the accessories. I don't want to charge through the ammeter so I will keep the cable going to the Starter Solenoid for now. I just want everything to work when the key is turned "ON". For my EFI and Electric Fans I have run a separate battery cables going directly to the battery itself. The added accessories like the MSD system and the Water/methanol Injection system is powered by a second fuse panel mounted under passengers side dashboard. I am installing a 200 amp Current Shunt top allow me to see what is actually happening at the battery. This will let me see whether I am pulling current or making current and charging the battery. I will replace the ammeter with a Volt meter on the panel to keep it looking close to correct.
If I have a wire from the Alternator Output connected to the Horn relay it pulls power and will discharge the battery slowly. That wire would not have 12 volts until the engine is running the way they designed it. Should I put a relay in there to power up the fuse panel when I want to drive the Corvette?
The original wires were designed to handle 40 amps to work with the ammeter. The shunt is mounted on the ammeter and that is why so many older Corvettes burn to the ground. The wires going through the shunt might be 10 gauge but more likely 12 gauge. That is not big enough for our new alternators.
How have other 1968 owners dealt with this? Is the current drain when the battery is hooked up the windshield wiper override switch?
When I bought my 1968 Corvette and went to Corvettes@Carlisle in PA back in 1991 I was so excited to have a 1968 C3 and it was there I learned it is the least desirable C3 of them all according to some at the show. They treated me like a second class citizen because of the 1968. And to make it worse when our C3's came up for their 25th anniversary they blew us off and brought in a bunch of identical 1978 pace cars in our place. They did give us a 50th reunion so I guess it has gotten better over the years.
I like the 1968 C3 as one of the best designs of the Corvette! I love the faces of the later 1970 LT1 Corvette owners when I blow them off the race track! To me the best music is the sounds of a Corvette with a 427 going around a track in a hurry, the motor revs so nicely and there is so much torque. I went drag racing one time in my Corvette and two guys wanted to buy the car after they saw the runs it made. According to my calculations the engine is more than able to get into the 11 second range pretty easily, it is noisy and F-A-S-T.
I spent almost a year building this 427 that I am using and it runs L88 pistons and the cast iron version of the cylinder heads. The compression is 12.25-1 after all was said and done, compression testing of the cylinders shows them to be in the 230-240 psi range. It is not only a old C3 but it is faster than my cousins 1967 BB Corvette was. I learned later in life that I indeed did overdo the building of the engine. Using this much compression is not a great thing but it does make power. When GM designed the hood for the L88 they "Knew" what they were doing as it brings lots of cold air into the combustion process making for a happier engine!
I Love my 1968 Corvette Convertible and I was fortunate enough be able to "thank" Zora personally for designing a Car like these. He autographed my 1968 Sales Brochure where they have a picture of a Corvette like mine for me at Carlisle be fore he died. I am just glad to have a chance to tell him just how much that car meant to me.
Old Oct 31, 2021 | 01:39 PM
7T1vette's Avatar
7T1vette
Power does NOT go thru the ammeter. Current is only flowing thru the power wires. The "ammeter" just uses a segment of that power wire as a current shunt to detect voltage drop over the length of that segment. That small voltage 'difference' is displayed on a galvanometer as "AMPS". When you changed (or added) the larger power wire, you didn't re-engineer the current shunt part of the circuit to allow the ammeter to function properly. If you attempt to direct all the current in the system thru the ammeter, you will likely destroy the ammeter and I'm not sure what other 'bad things' would occur.
Old Oct 31, 2021 | 01:52 PM
Rescue Rogers
The cooling was the single biggest issue with the model. That was changed to a bigger radiator support and larger opening that spread in front of the frame rails instead of in between them. That gave the radiator a couple of square feet larger cooling surface area. THat and the rear kick up frame supports. That helped my 68 immensely. adding a bigger air dam helped funnel more air up into the air chamber in front of the radiator. I still have the smaller 67 front spindles on mine and havent had any issues with that. If I road raced alot I may have issues but I just dont have a local course close enough.
Old Nov 1, 2021 | 12:45 PM
L-46man's Avatar
L-46man
Differences...one year model changes. it's been said that a '68 is 85% of a C-2!
You want ISSUES??? Try a $100,000 2020 C-8......wouldn't touch THAT with a barge pole!
Old Nov 1, 2021 | 07:58 PM
roscobbc's Avatar
roscobbc
The real problem with '68's is the road tests done by journalists 'back in the day'. Many commented how poor the interior quality was and other detrimental remarks about various features of the build - they probably made similar comments about Mopar and AMC vehicles from the day. I'm sure there are very few vehicles about today in general use from that period that still have the original interiors, paintwork and other items (whether 68' Vette, Mopar or AMC) so its all a mute point and typical of modern plagiaristic journalism where the 'scribe' is too lazy to use his or her brain and finds it easier to re-write something from 40 or 50 years ago. Trouble is that enthusiasts 'new' to the hobby and not around 'in the day' will read all this crap and believe it's true.........
Old Nov 1, 2021 | 08:33 PM
69L88's Avatar
69L88
Hey, it’s all on the Internet so it HAS to be true - right?
Old Nov 1, 2021 | 09:15 PM
thatcorvetteguy's Avatar
thatcorvetteguy
The changes from a 68 to later cars doesn't mean that it was a upgrade it's more like Chevrolet could build them cheaper.
To First year model "issues"
